rear brake conversion help please..
Old Sep 16, 2008 | 11:32 PM
Johnny Is Bored's Avatar
Default rear brake conversion help please..
well guys i did my research but just wanted to double check to see if i have everything in order. Please correct me if I'm wrong. I have 96 civic DX hatchback and have bought some 99 abs rear disk brake off an integra. As far as I know everything should plug and play except i would have to use the 99-00 civic si brake cables.
Am i suppose to use the integra brake lines or the civic si? ( and would they bold right up?)
do i have to replace any one of the parts below?
.99-00 Si master cylinder
.proportioning valve
.brake booster
Thank you
Old Sep 16, 2008 | 11:50 PM
Default Re: rear brake conversion help please.. (Johnny Is Bored)
please bump if you view
Old Sep 17, 2008 | 03:16 AM
Old Sep 17, 2008 | 06:47 AM
OMGWTFBBQ!'s Avatar
You should replace your prop valve, but some people will say you don't have to.
The integra e-brake cables will fit, but you may have to leave one of the brackets unbolted for them to reach your e-brake handle, thats what I had to do on my coupe.
You'll also have to cut the e-brake sensor plugs unless you want them dangling around youre brakes and wheels.
Modified by OMGWTFBBQ! at 10:53 AM 9/17/2008
Old Sep 17, 2008 | 06:56 AM
Hanmin's Avatar
e brake sensor plugs??? you mean abs sensor???=]
Old Sep 17, 2008 | 07:40 AM
EL Vap133's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">e brake sensor plugs??? you mean abs sensor???=]</TD></TR></TABLE>
Yes, you do not require it.
Also, the 96-00 DX and the 99-00 Si (which came with rear disc brakes from the factory) share the same prop valve so you do not need to replace it. I did this swap in my old Sedan (DX) and my Hatch (DX) and I used the same prop valve with no problems. I also used the same brake booster because the DX and Si booster is the same, I did however use the 99-00 Si Master Cylinder.
Old Sep 17, 2008 | 11:10 AM
Thanks for all the comments!!!! I really appreciate it!
Old Sep 17, 2008 | 11:13 AM
and also one more question I am also planning to upgrade my brake lines which of the following am i suppose to use the 98-01 integra or the 99-00 civic si and will they bolt right up?
Old Sep 17, 2008 | 12:37 PM
OMGWTFBBQ!'s Avatar
Wow, I actually said e-brake sensors?
Fail.
You need 99-00 SI brake lines, I used Goodridge SS lines on my swap. They're pretty much the best way to go as far as SS lines are concerned.
Old Sep 18, 2008 | 06:48 AM
EL Vap133's Avatar
Default Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! &raquo;</TD></TR><TR><TD CLASS="quote">Wow, I actually said e-brake sensors?
Fail.
You need 99-00 SI brake lines, I used Goodridge SS lines on my swap. They're pretty much the best way to go as far as SS lines are concerned. </TD></TR></TABLE>
Agreed, that is what I used.
Old Sep 19, 2008 | 01:33 PM
Thank you for all the comments
Spitz911
14
Aug 3, 2012 07:11 AM
kirkland08
14
Mar 17, 2011 08:58 PM
HondaGarage
May 23, 2007 06:31 PM
DARKSIRACER
Nov 9, 2005 07:03 PM
astroxtc
Nov 7, 2005 11:01 AM
