EK rear disc question
Ok so i just bought a rear disc conversion (or part of it at least) i just need a master cylinder e brake cable and brake lines... Now ive done some research and found that since the rear discs are from a GSR i need GSR brake line which is fine but.. Can i use an Si master cylinder/proportioning valve and an Si e brake cable with the GSR brakes? Any info would help thanks.
Re: EK rear disc question
awesome thank you!!! that will save me time trying to find that stuff... now ive also heard that EX e brake cables work too is that right?
EDIT: Reasoning for a rear disc conversion not doing much is that only ~15% of your braking power is in the rear. If you want a real notice in braking power, do a front disc conversion, where ~85% of your braking power is. Or maybe consider a bigger rotor conversion. Like some S2K rotors.
your oem master and proportioning valve will be fine. e-brake cables from an si. rear brake lines can be from an integra or civic si, doesn't matter since they're the same.
GeoMetry
11-11-2015 09:20 AM
'96-EJ6Hatch
32
03-18-2012 05:21 PM
enrique
02-26-2004 05:17 PM
