P28 ecu running an OBD2A GSR
Old Sep 15, 2008 | 10:15 AM
dynimitejack's Avatar
Default P28 ecu running an OBD2A GSR
Ok when I first bought my car 98 ek it had a obd1 d16z6 with a virgin P28 ecu and jumper harness. I blew this engine and had a shop in Dallas swap in a obd2a gsr engine, with a p72 ecu. I was having problems that you can read about here: https://honda-tech.com/zerothread?id=2357677
So while sitting and trying to think about what could be causing this problem I remembered the p28 ecu sitting in my closet with the jumper harness. So just out of curiosity I unplugged the p72 and plugged in the p28 and my car started idled fine and cleared 2 cel (no up stream o2 sensor, and Idle control system malfunction)
My question: Is it ok to use the virgin obd1 p28 ecu rather than the factory p72? Can anyone tell me how different the fuel maps for the p28 from the p72, I know the d16z6 is a 1.6l and the b18c1 is a 1.8l so will the p28 run a more lean mixture than the p72?
In the post ^there I think the problem with the rev-limiter comming in at 5k rpms is caused by the ecu.
Old Sep 15, 2008 | 10:58 AM
THC07's Avatar
Default Re: P28 ecu running an OBD2A GSR (dynimitejack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynimitejack &raquo;</TD></TR><TR><TD CLASS="quote">Ok when I first bought my car 98 ek it had a obd1 d16z6 with a virgin P28 ecu and jumper harness. I blew this engine and had a shop in Dallas swap in a obd2a gsr engine, with a p72 ecu. I was having problems that you can read about here: https://honda-tech.com/zerothread?id=2357677
In the post ^there I think the problem with the rev-limiter comming in at 5k rpms is caused by the ecu.</TD></TR></TABLE>
No dude, do not run a p28 in place of a p72. Huge difference high cam, check it out
p28
p72
Old Sep 15, 2008 | 11:00 AM
94EG8's Avatar
Seagull Management
A stock P28 is gonna run too lean to run a GS-R properly, also the vtec engagement point and rev limiter wont be where they should be. But if you get it chipped with GS-R basemaps you will be fine.
Old Sep 15, 2008 | 11:03 AM
THC07's Avatar
Default Re: P28 ecu running an OBD2A GSR (94EG8)
yea, what he said.
&lt;---Sells Chips
Old Sep 15, 2008 | 11:20 AM
Ya I figured it would run too lean. I got excited though when the cels were gone though.
If I get the p28 chipped with a gsr base map will the butterflies on the intake manifold still function? and will I have to replace the obd2a dizzy with an obd1?
Old Sep 15, 2008 | 11:58 AM
94EG8's Avatar
Seagull Management
Default Re: (dynimitejack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynimitejack &raquo;</TD></TR><TR><TD CLASS="quote">If I get the p28 chipped with a gsr base map will the butterflies on the intake manifold still function? and will I have to replace the obd2a dizzy with an obd1?</TD></TR></TABLE>
No and no, just make sure the secondary butterflies remain open at all times.
Old Sep 15, 2008 | 01:36 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynimitejack &raquo;</TD></TR><TR><TD CLASS="quote">Ya I figured it would run too lean. I got excited though when the cels were gone though.
installing IAB to the p28 is an option.
Old Sep 15, 2008 | 07:18 PM
IAB?
Old Sep 15, 2008 | 07:34 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynimitejack &raquo;</TD></TR><TR><TD CLASS="quote">IAB?</TD></TR></TABLE>
IAB -&gt; Intake Air Bypass, otherwise known as secondary butterflies.
Old Dec 31, 2008 | 09:37 PM
Archangl's Avatar
could a virgin p28 still run the vtec on a gsr? I have an ls vtec but it at the p28 vtec crossover (5500 rpms) it just cuts out like the rev limiter.
Jdmlifetyper
Mar 26, 2012 11:35 PM
Nikademo
Apr 9, 2010 05:32 PM
93bubble87
Engine Management and Tuning
11
Jan 5, 2010 07:59 PM
McFlurry
Jan 30, 2008 12:32 PM
brbHPR
Mar 13, 2003 09:19 PM
