b18c1 jrsc questions about fuel and ignition timing
hello i have a couple of questions about my setup i have a b18c1 jrsc with low compression pistons they are about 9.32:1 ratio. i have the stepper pulley and b20 crank pulley on. i know that on a stock b18c1 motor you have to adjust the timing to 8-10 btc, so what should i retard my timing to? and i am also running a 255lph wahlbro pump with dsm 440cc injectors and a resistor box i have the aem fpr and fuel rail im currently at about 42-43 psi should i add more fuel ? the base map i have for the setup is a jrsc b18c1 with 440cc injectors if that matters. I am definitely going to get the car tuned asap with a hondata s300 that i brought and a aem wideband but i was wondering if any1 had any input on how to get the car running decent until i can get it tuned. Thanks JRSC GURU's
2K Teggy
Oct 16, 2003 06:26 PM
