Losing Power
Old Sep 12, 2008 | 07:45 AM
PhillyB16's Avatar
Default Losing Power
I have a 1991 Integra with a B16. I have run into a problem where the car idles perfectly, but once I turn on the head lights or rear defrost, anything that draws power from the motor. The engine wants to die, but nothing dims as if the altenator was bad because it is fine.
My question is, is there a sensor or relay that controls something like this?
Thanks for the help
Old Sep 13, 2008 | 12:05 PM
ef_88_hatch's Avatar
Default Re: Losing Power (PhillyB16)
it could be many things. first i would check the battery connections. will you have the terminals off the batter i would check the voltage of the batter to see if your battery is getting old or worn out.
Old Sep 13, 2008 | 03:54 PM
civic95hbvtec's Avatar
Battery or Alt
Old Sep 15, 2008 | 04:13 AM
PhillyB16's Avatar
Default Re: (civic95hbvtec)
I don't think it is the battery cause it is pretty new and starting is not a problem. I dunno I thought it could be the alternator, but like I said there is no dimming just the motor dying. What about the volatge regulator?
Old Sep 15, 2008 | 07:27 PM
Default Re: (PhillyB16)
i don't think it is the voltage regulator or when you rev up the motor the lights would get supper bright.
Old Sep 16, 2008 | 03:07 PM
PhillyB16's Avatar
Default Re: (ef_88_hatch)
Well i don't think its the battery its starts up perfectly, does anybody have any other ideas??
Old Sep 16, 2008 | 04:21 PM
Dartanian's Avatar
Sounds like a bad ground. Check all of them to make sure they are clean and intact.
Old Sep 19, 2008 | 11:49 AM
PhillyB16's Avatar
Default Re: (Dartanian)
Are there any others beside the one connecting the motor to the frame and the one to the battery?
4dr_Noob
36
Nov 14, 2011 07:07 PM
9sludei0
Aug 29, 2010 12:22 PM
MzStreetracer
Mar 6, 2007 08:38 PM
90AcuraIntegra04
Nov 1, 2005 07:19 PM
daveid001
Feb 13, 2005 03:04 PM
