IAB problem HELP !!!!!
Old Sep 9, 2008 | 07:29 PM
connor53's Avatar
Default IAB problem HELP !!!!!
ok so i swapped a b18c into my 99 civic ex i ran the iab wire to the a26 pinout as soon in the reference section...i have power to the plug at the solenoid and vacuum at the diaphragm, i had my brother get into the car and rev the engine to 6000 rpm's so i could see if the diaphragm opened the secondaries up....nothing....i shut the car off and the diaphragm stays close....even know the vacuum is gone...What is my problem Here? please help im so sick of working on this.
Old Sep 10, 2008 | 08:43 AM
IN VTEC's Avatar
Default Re: IAB problem HELP !!!!! (connor53)
Is the ECU driving the IAB via high-side of low-side driver?
Old Sep 10, 2008 | 12:25 PM
connor53's Avatar
Default Re: IAB problem HELP !!!!! (IN VTEC)
not sure what you mean?????
Old Sep 10, 2008 | 12:43 PM
IN VTEC's Avatar
Does the ECU switch the ground or the 12VDC+ to turn the solenoid on?
Is the ECU OBD-2 or OBD-1?
Old Sep 10, 2008 | 12:47 PM
connor53's Avatar
ecu is obd2 it uses a 12v to switch the ground. I have the black going to a ground and the other wire going to the a plug pin 26 on the ecu...
Old Sep 10, 2008 | 01:29 PM
connor53's Avatar
problem fixed....that cap on the top of the solenoid that works as a filter was clugged ....therefore not letting an air excape from the diaphragm...thanks for the help in vtec.
dsmslyr55
Engine Management and Tuning
Jun 4, 2009 08:32 PM
Eclpze97
Jun 28, 2004 11:56 AM
smnowell
20
Oct 21, 2003 10:28 AM
u2civic1
Aug 1, 2003 01:11 PM
TheKid
Jul 23, 2003 05:35 PM
