distributor turns vs cam turns
Old Jul 25, 2002 | 01:19 AM
austrian type-R's Avatar
Default distributor turns vs cam turns
Is 360 degree distributor turn equal to 360 degree camshaft turn. I want to know, cause I toke off the distributor for cleaning. Now when I turn the distributor shaft 360 degree does it fire right for the cylinder when I put it back to the head. Or do I need more turns to get the right spark for each zylinder again. Of course I try to NOT turn this ditributor shaft.
Old Jul 25, 2002 | 01:41 AM
DutchITR1689's Avatar
Default Re: distributor turns vs cam turns (austrian type-R)
It's connected directly, right?
Old Jul 25, 2002 | 01:48 AM
Default Re: distributor turns vs cam turns (DutchITR1689)
yeah the distributor shaft is kinda pluged into the intake cam.
Old Jul 25, 2002 | 01:51 AM
I think 360 deg turn won't be a problem. How about 180 deg turn. Will the shaft still fit?
Old Jul 25, 2002 | 02:02 AM
yes, I think so, but I have painted it black.
Old Jul 25, 2002 | 02:28 AM
kenji's Avatar
25 Year Member
You can do a 15120 degree turn (42 turns) and reinstall the distributor and it will be fine.
But, you can not install the distributor 180 degrees out. It is possible if you force it on but you will know that you did this when you start the motor. It makes an awful sound.
The cam and distributor are keyed in such a way that when installed properly the two just slide together nicely. But, when installed 180 degrees out they do not mate perfectly.
-kenji
/edit - spelling error/
[Modified by kenji, 3:29 AM 7/25/2002]
Old Jul 25, 2002 | 02:34 AM
Default Re: distributor turns vs cam turns (kenji)
thx, okay I will make a 15120 degree turn just to be safe when install it back
[Modified by austrian type-R, 12:35 PM 7/25/2002]
Old Jul 25, 2002 | 02:45 AM
Been there done that?
Old Jul 25, 2002 | 03:41 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
simple. put the motor on tdc for the #1 cylinder, pull the distributor cap, and install the distributor with the rotor facing the number 1 electrode (?) under the cap. it will be facing either #1 (correct! ) or #4 (wrong! )
warfield21
Apr 15, 2017 12:26 PM
DarkFlame
Jan 16, 2014 11:17 AM
Atomic1
Mar 17, 2010 06:17 PM
racekar
Oct 19, 2004 09:32 PM
LB CRX
Jul 18, 2002 07:46 PM
