t3 turbo lag question
Old Jul 25, 2002 | 12:25 AM
turbogsr13z's Avatar
Default t3 turbo lag question
i spool up on my gsr pretty quick but my full boost dont kick in till like 3500 and its weird cuz my engine gets louder and works overtime but for some reason it pulls back ......and then after it kicks in is that turbo lag or wut? by the way stock piping and exhaust thinkin about goin 2.5 and no cat
Old Jul 25, 2002 | 03:06 AM
rjardy's Avatar
Default Re: t3 turbo lag question (turbogsr13z)
when you say it kicks back do you mean that the boost drops?
Rob
Old Jul 25, 2002 | 04:25 AM
symba's Avatar
changing to the 2.5 will help you spool up, but i don't understand what you mean by the engine pulling back. please explain
[Modified by symba, 1:26 PM 7/25/2002]
Old Jul 25, 2002 | 04:31 AM
DSF's Avatar
DSF
What's your fueling situation? What turbo?
Old Jul 25, 2002 | 08:02 AM
csufweed's Avatar
like i told you, you got problems with your set-up. fix that before you start tryin to make mods. and please list everything u have on your custom set-up or else no one can help you!
Old Jul 25, 2002 | 10:14 AM
Default Re: t3 turbo lag question (csufweed)
rev hard manifolld t3 turbo drag piping boostin 7 2.5 inch downpipe stock piping and cat manual boost controller,msd inlin fuel pump, black fmu,stock injectors spearco intercoole, deltagate wastegate.
Old Jul 25, 2002 | 11:39 AM
DigitalFusion's Avatar
i am willing to bet that if u made some attempt to make ur posts readable( meaning not long run on sentances and no structure) you would get a lil better response.
Old Jul 25, 2002 | 01:01 PM
shadowdawn's Avatar
Default Re: t3 turbo lag question (CustomCockpits)
I have his same problem and nrealy the same setup except I have a t3/t4e I get boost early on enough but it doesnt start pulling until that magic mid 3000 mark like around 3500rpms.... I will be a couple psi into boost lets say 3-5 before I hit 3000rpms.... but its not really moving... but as soon as I get over the 3000 hill it starts pulling hard... Its rather strange.
My fuel setup is stock injectors, msd inline pump, 12:1 fmu, and s-afc. My idle fuel pressure is 38psi with hose connected. I don't think I'm running lean.
rickturboteg
Aug 27, 2006 09:23 AM
nickromeo
Apr 14, 2006 11:20 AM
jtracing919
Apr 9, 2006 01:01 PM
19sec beast
Mar 20, 2005 06:50 AM
Rhythm Racer
Mar 3, 2003 10:24 AM
