Help! turbo not spooling?
Old Apr 7, 2006 | 08:01 PM
jtracing919's Avatar
Default Help! turbo not spooling?
I have a b18c. I just rebuilt it and put a turbo on it. It has a max rev manifold, t3/t04e 57 trim 63 a/r. 2.5 downpipe, 3 in exhaust. tial 38mm wg, drag icooler with 2in. piping in and 2.5 out. I am showing vac. on my boost gauge and in my datalog, but it doesnt make any boost. i pulled the charge piping off before the throttle body and it is pushing air and seems to pick up around 4000rpm. I am under the impression this configuration should spool around 3800 rpm, but mine doesnt show any positive pressure and i have run up to 5500 rpm. any ideas?
Old Apr 7, 2006 | 08:14 PM
JDMAppeal's Avatar
Default Re: Help! turbo not spooling? (jtracing919)
check all of your couplers
Old Apr 7, 2006 | 08:26 PM
LilCivic04's Avatar
Default Re: Help! turbo not spooling? (JDMAppeal)
definitely make sure all your couplers are on tight
Old Apr 7, 2006 | 08:37 PM
Default Re: Help! turbo not spooling? (LilCivic04)
i have checked the couplers and they are all tight. I looked at my data log file and the map reading at 880rpm was 24 and at 5500 it read 23..
Old Apr 7, 2006 | 09:02 PM
no2unenolife's Avatar
make sure there arent any rips on the couplers, a tiny rip affected my car a lot
Old Apr 8, 2006 | 04:24 AM
coneheadsracing's Avatar
Default Re: (no2unenolife)
make sure the wheels of the turbo can spin.
Old Apr 8, 2006 | 08:21 AM
96 GSR-T's Avatar
Default Re: (coneheadsracing)
is it possible for the wastegate to be stuck open?
Old Apr 8, 2006 | 08:25 AM
tallyturbo's Avatar
its possible
Old Apr 8, 2006 | 10:20 AM
adictionbass's Avatar
Default Re: Help! turbo not spooling? (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtracing919 &raquo;</TD></TR><TR><TD CLASS="quote"> i pulled the charge piping off before the throttle body and it is pushing air and seems to pick up around 4000rpm. I am under the impression this configuration should spool around 3800 rpm, but mine doesnt show any positive pressure and i have run up to 5500 rpm. any ideas?</TD></TR></TABLE>
when your just sitting somewhere, your car will not make boost the same as when the motor is under load (driving it). So you cant really go off of that..
Old Apr 8, 2006 | 10:21 AM
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">is it possible for the wastegate to be stuck open?</TD></TR></TABLE>
do you have the spring and/or the fire ring in place ?? Ive def. seen a few people leave the fire ring off the wastegate.
Old Apr 8, 2006 | 12:41 PM
I can see the wheel spinning in the compressor housing. i have felt under the dump tube and nothing is coming out of it. i am going to double check all my connectors and my manifold gasket and wastegate mounting to make sure nothing is leaking. if its not that i am at as loss..
Old Apr 8, 2006 | 04:42 PM
Soccerking3000's Avatar
if you are free revving it it wont build any boost....
Old Apr 9, 2006 | 12:16 PM
LilCivic04's Avatar
Default Re: Help! turbo not spooling? (Soccerking3000)
well i guess make sure your intercooler doesn't have any holes in it i guess if you have checked all your couplers
Old Apr 9, 2006 | 01:01 PM
10 bucks says he is free revving it and thats causing it to not spool
RonMexic07
Jun 12, 2006 07:23 PM
Eaglekper0046
May 17, 2006 11:32 AM
Slammd Sol
Jul 18, 2004 10:27 AM
integraautox
May 24, 2003 03:33 PM
turbogsr13z
Jul 25, 2002 01:01 PM
