Fog Lamp Install ?
Old Sep 4, 2008 | 08:52 AM
IB4TL FTW's Avatar
Default Fog Lamp Install ?
http://cgi.ebay.com/ebaymotors....m245
My friend recently purchased these foglamps. We attempted an install yesterday. Fitment was a pain, but they are on and look good. Problem is, we wired them exactly as the schematic provided displays. We get no power to the switch or lights. We moved both the ground to the switch and to the driver side light. Still got nothing. Was curious if anyone else has used these or similair aftermarket foglamps and can give us some advice ???
Old Sep 4, 2008 | 08:55 AM
DTA-Zombie's Avatar
does the switch get power? most likely is either not getting a good ground or the fuse..
Old Sep 4, 2008 | 08:59 AM
IB4TL FTW's Avatar
Default Re: (DTA-Zombie)
no power anywhere, came with brand new fuse, we checked and it is brand new. we tried grounding three different places with both grounds. There are three wires that come out of the switch, one for ground, one negative with amp, and a positive with female adapter. The schematics show no male or positive going into the positive/female coming out of the switch. This makes no sense... ?!? ...why I am on here lol
Old Sep 4, 2008 | 10:05 AM
DAP97SI's Avatar
Did you run the cable to the battery?
Old Sep 4, 2008 | 10:47 AM
IB4TL FTW's Avatar
Default Re: (DAP97SI)
Yes!!! hahaha I double checked it multiple times, I thought too ... haha
Old Sep 4, 2008 | 01:58 PM
DAP97SI's Avatar
I have the same fogs, I just installed them a couple of days ago. Make sure you have both grounds, the cable to the battery, and the cable that plugs into the fuse box. Also check the fuses.
Old Sep 4, 2008 | 03:26 PM
big_poppa492004's Avatar
I just posted this exact same question earlier today, had the same problem. Refer to my thread (last post) as I told what [I][/]my problem was...
https://honda-tech.com/zerothread/2380398
Ohh yeah, since you wired one wire (mine was black, with an in-line fuse) to the battery, MAKE SURE the other wire (mine was blue, NOT the blue one that connects behind the fuse box, should be the only other wire left) goes to your fuse box plug that comes on when your park lights turns on! Other than that, check grounds and mainly PLUG connectivity!
I know it sounds weird to have TWO sources of power, but it just does...
Here is another link that helped me in figuring out where everything goes and how its wired, its not Honda, but it wires the same.
http://www.accessconnect.com/f...g.htm
Modified by big_poppa492004 at 4:31 PM 9/4/2008
Modified by big_poppa492004 at 4:35 PM 9/4/2008
Old Sep 6, 2008 | 12:04 PM
suthernbred904's Avatar
so your saying that the plug thats inside where the switch is plugs into the fuse box in the car? that might be why im having problems..
Old Sep 6, 2008 | 06:23 PM
IB4TL FTW's Avatar
looks like weve got some more work to do haha... hopefully my hids wont be as difficult
andrewtheaccord
Lighting
Mar 19, 2010 05:33 PM
imadigitalgod
38
Nov 1, 2006 12:39 AM
JDM-EJ1
11
Mar 14, 2006 11:14 AM
VTECAcuraGSR
Apr 17, 2005 05:40 AM
PetroGuyX
Jun 7, 2004 06:11 PM
