TPS problem!
Old Aug 25, 2008 | 06:33 PM
b20vtech's Avatar
Default TPS problem!
somehow when i set the TPS to .5v at close throttle the motor starts up and dies quickly... the lowest i can set the tps at close throttle is .7v ..... the WOT is at 4.5v which i think it's normal.... what do u guys think it could be? this is on a stock internal b20v with upgraded TB,manifold, and header... and it's running on a p28 chipped ecu and i dont know what program.
Old Aug 26, 2008 | 07:48 PM
b20vtech's Avatar
Default Re: TPS problem! (b20vtech)
bump for some answers
Old Aug 26, 2008 | 07:57 PM
gibsanez's Avatar
How does it act at .7v closed?
Old Aug 27, 2008 | 02:04 AM
Street Rice's Avatar
Sounds like the idle screw isnt screwed out all the way, try that
Old Aug 27, 2008 | 01:26 PM
b20vtech's Avatar
Default Re: TPS problem! (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">How does it act at .7v closed?</TD></TR></TABLE>
it idles around 700-750 rpm with a bog... kinda like backfiring...
Old Aug 28, 2008 | 05:14 AM
b20vtech's Avatar
bump for help!!
Old Aug 28, 2008 | 05:47 PM
97coupecivic's Avatar
i'm having a similar problem
do you have a little bog when you give little hits of gas, and do you find your car backfires and runs a little rich?
Old Aug 29, 2008 | 01:54 PM
b20vtech's Avatar
Default Re: TPS problem! (97coupecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97coupecivic &raquo;</TD></TR><TR><TD CLASS="quote">i'm having a similar problem
that is the same exact problem im having!!! if i give it a little tap of gas from the pedal, it bogs, and when i try to keep a steady rpm say like 2500rpm i hear it backfiring, and i smell gas rich buring from the tip of my exhaust pipe!!
I also have been trying to adjust the TPS back and forth with no luck, where ever i set the Volts at on the TPS it doesnt stop the bogging or backfiring... the idle on this motor is not all that good too!! it stays right at 700-800rpm but keeps on going from 700-800 like it's having hard time idling, if i rev it up to like 2000rpm or so, it falls back down pass 600rpm like it's going to die before the rpm goes back up! I want to dyno tune the motor but im not sure if it's gonna fix this problem....
Somebody Help!!
Old Aug 29, 2008 | 03:53 PM
b20vtech's Avatar
.62v Closed throttle
4.55v WOT
this is how the motor idles on normal operating temperature and the TPS is set to .62v closed and 4.55v WOT... I also tryed .5v closed still idles the same as the .62v closed....
BTW, i am using a 94 civic CX OEM TPS sensor on the Professinal product 68mm tb
Old Aug 29, 2008 | 05:59 PM
kalm_traveler's Avatar
when I set TPS's I only focus on being exactly 4.50v at WOT. Far as I can tell, the ECU is fine with lower than 0.5 closed because 3 of my cars were lower than that out of the factory.
If you're having a bog, I would guess there's an airflow problem. Make sure your idle screw is where it should be and that your fuel system can keep up with all the extra air a 68mm TB lets in.
Old Aug 30, 2008 | 01:11 PM
b20vtech's Avatar
Default Re: TPS problem! (kalm_traveler)
[QUOTE=kalm_traveler] Far as I can tell, the ECU is fine with lower than 0.5 closed because 3 of my cars were lower than that out of the factory.
QUOTE]
what about if it's at .6v closed?? will the ecu still be okay with it?
Old Aug 30, 2008 | 01:14 PM
b20vtech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kalm_traveler &raquo;</TD></TR><TR><TD CLASS="quote">
If you're having a bog, I would guess there's an airflow problem. Make sure your idle screw is where it should be and that your fuel system can keep up with all the extra air a 68mm TB lets in. </TD></TR></TABLE>
My idle screw is all the way closed, i am running a GSR fuel pump and obd2 b20b fuel injectors.... do u guys think a dyno tune will solve this problem??
Old Aug 30, 2008 | 01:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">
what about if it's at .6v closed?? will the ecu still be okay with it?</TD></TR></TABLE>
If that's where you need to be for normal idle speed then you're fine. A Civic I tested OEM was at like 0.38v so .6 isn't that surprising.
I thought about this some more and a bog would be too much fuel, not air. A tune may be exactly what you need. How's your timing?
Old Aug 30, 2008 | 09:09 PM
b20vtech's Avatar
I thought about this some more and a bog would be too much fuel, not air. A tune may be exactly what you need. How's your timing? </TD></TR></TABLE>
it smells rich from my exhaust. Timming is a little off on the Intake cam(retard), i think it's due to the head being resurfaced before.
ek souljah
Feb 1, 2011 12:04 PM
b20vtech
Aug 30, 2008 01:18 PM
N2O INTEGRA
Sep 14, 2007 12:03 PM
guywitaDA
Dec 29, 2005 10:24 PM
10
Jun 2, 2003 02:46 PM
