piston install
Old Aug 18, 2008 | 01:16 PM
adam00's Avatar
Default piston install
can I install forged pistons and rods with out taking out my motor, can I take off the head and and oil pan/oil pick up and leave in the crank or would I have to replace the main bearing?
Old Aug 18, 2008 | 02:12 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: piston install (adam00)
Yes you can install the new rods and pistons that way. It would be a good idea to size up and install new bearings too, last thing you want is to assemble and start the car just to ruin the crank/rods/bearings.
Old Aug 18, 2008 | 02:20 PM
DonF's Avatar
Default Re: piston install (24TEN)
Only if you are sure the piston to wall clearance is correct.
Old Aug 18, 2008 | 02:32 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: piston install (DonF)
good point
Old Aug 18, 2008 | 03:03 PM
adam00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Only if you are sure the piston to wall clearance is correct.</TD></TR></TABLE>. You mean make sure the cylinder walls aren't worn, the motor only has like 50k on it do you guys think I should replace the main bearings if I don't have to then I really don't want to.
Old Aug 18, 2008 | 03:27 PM
DonF's Avatar
No. Read the spec sheet with the pistons.
Old Aug 18, 2008 | 04:13 PM
adam00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">No. Read the spec sheet with the pistons. </TD></TR></TABLE>. Wat does the spec sheet say the piston size and max cylinder size they will go into and btw my pistons are going to be specialy made so I can use h22 rods in a f22
Old Aug 18, 2008 | 05:12 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam00 &raquo;</TD></TR><TR><TD CLASS="quote">. Wat does the spec sheet say the piston size and max cylinder size they will go into </TD></TR></TABLE>
it tells you what your piston to wall clearance should be for the specific pistons you have
Old Aug 18, 2008 | 05:29 PM
adam00's Avatar
Default Re: piston install (BILLETGRIP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">
it tells you what your piston to wall clearance should be for the specific pistons you have</TD></TR></TABLE>. So what do I do measure the cylinder walls then measure the pistons and subtract the sizes and then I get the piston to cylinder wall clearence
Old Aug 18, 2008 | 06:43 PM
BILLETGRIP's Avatar
https://honda-tech.com/zerothread?id=1258944
found this when i searched
Old Aug 18, 2008 | 07:30 PM
adam00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1258944
found this when i searched</TD></TR></TABLE> that's pretty much the same thing I said but I didn't say measure the piston skirts
Old Aug 19, 2008 | 05:29 PM
adam00's Avatar
Bump
Old Aug 19, 2008 | 05:48 PM
BILLETGRIP's Avatar
why are you bumping? what question hasn't already been answered?
Old Aug 19, 2008 | 06:10 PM
adam00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">why are you bumping? what question hasn't already been answered?</TD></TR></TABLE>. I want to know if I have to replace my main bearings because if the only have 50k on them then the should be good for another 150k also it would be alot easyer to not have to change them because the motor will be in the car when I'm doing this
Old Aug 19, 2008 | 06:26 PM
BILLETGRIP's Avatar
thats your call. but it already sounds like you answered your own question.
AlienKrOZ
Apr 27, 2006 08:54 AM
P1mpSlap
Jul 9, 2003 11:46 AM
drjondurst
May 20, 2003 09:12 PM
B19CivicHB
Jun 23, 2002 08:15 AM
speedymon
Jan 5, 2002 10:19 AM
