Detailed piston install process..? (help me out)
Old May 15, 2003 | 02:02 AM
drjondurst's Avatar
Default Detailed piston install process..? (help me out)
Im asking this in this forum because I know alot of you here have done bottom end work for boost.
Im no where near the point of building my block yet but Im trying to learn what I need to do. I just want to name the things I know to do and want you guys to tell me if Im missing anything at all. Lets say I already have the head off and the shortblock is on an engine stand.
1. Disconnect rod caps (i think thats what they're called)
2. Push pistons from the bottom out of the top of the block.
3. Install new rings on pistons.
4. Make sure rings are set in the right order/sequence. (the gaps)
5. Install pistons on rods (still have no idea how this works)
6. Hone cylinders with a drill, honing device, and WD40 for about a minute/cylinder.
7. Use ring compressor to install pistons.
8. Torque rod caps.
9. -Is there where you would measure bearing clearances?-
10. Done with piston/rod install.
As you can tell, alot of parts of the process are hazy to me. I've never had any real experience doing this.. just reading as much as possible. I should probably get a helms or something.
Anything Im missing/doing wrong/doing right?
Old May 15, 2003 | 03:54 AM
Turbo92Si's Avatar
Default Re: Detailed piston install process..? (drjondurst)
Old May 15, 2003 | 05:55 AM
drjondurst's Avatar
Default Re: Detailed piston install process..? (Turbo92Si)
Thx for the suggestion.. anyone else?
Old May 15, 2003 | 04:15 PM
drjondurst's Avatar
guess I'll try bumpin this one more time.
Old May 15, 2003 | 04:21 PM
senpai's Avatar
Default Re: (drjondurst)
Sonny' website: http://www.muller.net/sonny/crx/
Old May 15, 2003 | 04:47 PM
m3bluegsr's Avatar
Default Re: (maztur)
when pulling pistons out. Put rubber hose on the rod bolts to keep them from scratching the walls.
Old May 15, 2003 | 05:22 PM
BoostedD15B7's Avatar
Default Re: (m3bluegsr)
make sure you put the rods on the pistons right....There should be an arrow or notch on top of piston to indicate front.....Look at your old rods pistons and install the same way....... if not you will spin the bearings. Just make sure your pistons and tangs on rods are the same as stock.
Old May 15, 2003 | 05:30 PM
drjondurst's Avatar
I've noticed the arrow on pistons before but havnt payed attention to them. Are the arrows supposed to face the intake valves or the exhaust valves?
Old May 15, 2003 | 07:02 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">I've noticed the arrow on pistons before but havnt payed attention to them. Are the arrows supposed to face the intake valves or the exhaust valves?</TD></TR></TABLE>
neither, they face the front of the engine. (timing belt)
Old May 15, 2003 | 07:33 PM
SOUNDEFFECTS's Avatar
Default Re: (TeStUdO)
Just a quick note....find out how much honing you need. A minute on each cylinder sounds excessive to me but maybe not.
Old May 20, 2003 | 08:56 PM
T3's Avatar
T3
Check out my sig FAQ..Tons of stuff.
for the okie
Old May 20, 2003 | 09:12 PM
RyanEJ8's Avatar
Default Re: (BoostedD15B7)
I don't see an arrow on mine, but they're not OEM they are SRP pistons, what should I be looking for?
BigMike0147
May 24, 2011 09:38 AM
1990_integra_DA9
Jul 21, 2008 06:22 AM
Youlose1305
Jul 1, 2006 09:53 PM
snake01
Nov 26, 2002 06:49 PM
B19CivicHB
Jun 23, 2002 08:15 AM
