Motor noise no clue what it is.
Old Aug 11, 2008 | 09:39 AM
user 98292739's Avatar
Default Motor noise no clue what it is.
I posted this up in F/I but i figured all motor guys might know this sound better.
I have already redid my valve lashes
I cranked it over with no ECU for over 10 times and there is no sound
No CELS
checked if i left anything in the valve cover
Bottom end is BRAND NEW 0 miles built by a very reputable builder
When i pulled the head off 3 months ago i pulled it running 100%
Timing on crank/cam is right on point
at this point i am completely baffled motor starts up basicly right away
y8 head:
crane turbo cam
crane springs/retainers
oem valve 3 angle valve job
crane cam
y7 block
aebs sleeved
cp 9.1 piston
eagle rods
crank micro polished/balanced
acl bearings
http://www.youtube.com/watch?v=4Sbi9E9vRNY
Old Aug 11, 2008 | 01:51 PM
projectTeG's Avatar
is it comming more from the top end? did you check the clearance between the head and the cam? also how are the lma's
Old Aug 11, 2008 | 02:18 PM
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">is it comming more from the top end? did you check the clearance between the head and the cam? also how are the lma's</TD></TR></TABLE>
so far we think its coming from the head.
head and cam? or head and block? i didnt do that. block has been milled .015 head had been decked before not sure how much.
the LMA SEEMS fine how do i check if its ok?
Old Aug 11, 2008 | 04:27 PM
projectTeG's Avatar
push them and if they stick on the rebound their bad. what i meant is on some D cams ive seen the vtec lobe is to big and hits the galley it runs in, ive had to grind some out of heads to get some cams to work.
Old Aug 11, 2008 | 06:01 PM
mine are pushed in do i just use a socket or something to push it in further?
the y8s are like this
Old Aug 11, 2008 | 06:04 PM
projectTeG's Avatar
if i remember correctly the y8s have the lma's on the forward side, not 90'd like the z6's.
AStar59
11
Jan 18, 2011 11:37 PM
accord2civic2prelude
Nov 11, 2009 01:10 AM
user 98292739
Aug 10, 2008 03:32 PM
madmax92
Apr 19, 2005 12:16 AM
RacerXI
Apr 6, 2004 12:24 PM
