Need help car shifts kind of funny!!
Old Aug 8, 2008 | 10:57 AM
MUGEN_EG95's Avatar
Default Need help car shifts kind of funny!!
I have a honda civic ej1 and my car shifts roughly. It sometimes revs before shifting almost like a 5 speed. When making a left or right on a corner a high rev will occur if i gas it. I also notice that my third gear shifts a lot quicker than all the other. I think that its my timing belt because my mechanic removed it when he was changing the water pump. Any help would be appriciated.
Old Aug 8, 2008 | 11:03 AM
v8killaz's Avatar
wtf is an ej1, sorry noob here. is it an auto. why dont you give us info about ur car year and engine than just ej1. and no i cant help becasue i wont google ej1
Old Aug 8, 2008 | 11:14 AM
MUGEN_EG95's Avatar
Default Re: (v8killaz)
oh excuse me about not being specific....its a 95 honda civic ex and yes its an auto. I had the engine swap so it has a zc block and D16Z6 VTECH head so its a ZC VTECH!
Old Aug 8, 2008 | 11:23 AM
davefromPA's Avatar
Default Re: (MUGEN_EG95)
when did you do the swap? what computer are you running? give us the numbers off the computer. have you checked your tranny fluid?
Old Aug 8, 2008 | 11:29 AM
MUGEN_EG95's Avatar
Default Re: (davefromPA)
i did it in feb or march and i'm just running the stock ex ECU. It acted like that after the swap.
Old Aug 8, 2008 | 12:49 PM
davefromPA's Avatar
do you ever drive it like its a manual? shifting? or drive like an ***? check your fluid. if not that take it to a transmisson place that checks it for free.
Old Aug 8, 2008 | 01:24 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA &raquo;</TD></TR><TR><TD CLASS="quote">do you ever drive it like its a manual? shifting? or drive like an ***? check your fluid. if not that take it to a transmisson place that checks it for free.</TD></TR></TABLE>
Uhh, hate to bust ur bubble but driving an auto like it's a manual and "manually shifting" IS driving it like an ***.
@ OP:
It doesn't have anything to do with your timing belt, despite the time line.
It sounds like a clutch pack is slipping, or the torque converter is...I'd have the trans checked out ASAP b4 you burn something out and are stranded. I'm not a tranny expert though, especially not an auto trans expert. Either way, I think it's going to get to dropping that trans and cracking it open.
Old Aug 8, 2008 | 07:02 PM
MUGEN_EG95's Avatar
Default Re: (Syndacate)
No I don't drive my car like a manual..thats hella dumb. You only do that if you're asking for a new tranny. My fluid is fine but wat i heard is that f the timing belt is not installed correctly or its a couple of bumps off then the car will run like ****. IDK i'll take it to a shop to find out the real problem. Thanks anyways.
Old Aug 8, 2008 | 08:41 PM
v8killaz's Avatar
timing belt has absolutly nothing to do with the trans but to make sure just rev ur car in neutral and see if the engine is revving freely and timing is good
Old Aug 10, 2008 | 01:20 PM
MUGEN_EG95's Avatar
i was wondering if the axle would have anything to do with the problem because my mechanic took it out to replace the boots.
NaruvariaIcaria
Dec 14, 2013 07:49 AM
slyda24
12
Jul 27, 2011 04:28 PM
darb2k
12
May 1, 2005 06:45 PM
saucycivic
Jun 14, 2001 09:03 PM
