b16 turbo ?
Old Aug 3, 2008 | 05:03 PM
stockb18c's Avatar
Default b16 turbo ?
have a b16a and choosing a turbo to go with...my last setup was b16a with AR .63 – 60 Trim on 10 psi and seem to be lag until vtec poped then moved...and was wonder if i get a AR .48 – 60 Trim will i still be able to pull at top rpm and not lose any power
Old Aug 3, 2008 | 05:33 PM
TheShodan's Avatar
Moderator
Default Re: b16 turbo ? (stockb18c)
The turbine housing is not going to help that much considering it is still using the same turbine wheel. Your compressor wheel/turbine wheel matched with that displacement is what's hurting your response a bit. To help with that, it may be time to downgrade entirely. A 50 trim w/ the same turbine wheel is in order.
Old Aug 4, 2008 | 06:45 PM
stockb18c's Avatar
ya but would it be cuttin off power at top if i say so doing a highway pull
Modified by stockb18c at 7:55 PM 8/4/2008
Old Aug 4, 2008 | 07:40 PM
TheShodan's Avatar
Moderator
Default Re: (stockb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb18c &raquo;</TD></TR><TR><TD CLASS="quote">ya but would it be cuttin off power at top if i say so doing a highway pull
Again, no, not with that compressor wheel. the turbine housing is 1/4 of the story in getting the right turbocharger.
hybrid1990crx
May 27, 2009 02:20 PM
thizboii
Feb 11, 2007 08:34 PM
alexsracing
Aug 21, 2005 08:44 AM
94integragsr
Jul 19, 2005 02:31 PM
YashiMotors
Oct 21, 2004 02:29 PM
