How to connect my EBC
Old Aug 1, 2008 | 07:39 PM
cpl rampage's Avatar
Default How to connect my EBC
Ok, ive been messing with this all night, and cant figure it out.
Previous setup: turboXS MBC connected to side port of turbonetics deltagate, running 15psi on a 7psi spring
New setup: Greddy profec b spec II
the instructions say this: connect the com port to the TOP of the wastegate. then connect the NC port to a good pressure source (vacuume manifold) It also then says the bottom port is connected to a presure source as well.
Now ive tried almost every combo of top/bottom, NC/NO and cannot get this to work, it goes to the spring pressure, or boosts as if the line was not connected to the gate. Could some one tell me exactly how it is supposed to be connected? and if possible, some base settings to work with? Oh and i did test the solenoid, it clicks when 12v is applied.
thanks in advance!
Old Aug 2, 2008 | 04:24 PM
Default Re: How to connect my EBC (cpl rampage)
Just got back from work, gonna try a few other settings, but any recomendations welcome
Old Aug 3, 2008 | 08:38 AM
DaveF's Avatar
the bottom port of the WG hook to compressor housing vacum port
top port of WG hook to COM on solenoid
NC to intake manifold pressure source.
those greddy boost controlers are a pita in my opinion, the screen sucks, and its like 1 button with a million adjustments.
i dont recomend doing pulls in the street & trying to adjust the contoller. put it on a dyno where you can be safe, look at the boost guage, make adjustments.. repeat...
Old Aug 3, 2008 | 04:51 PM
Default Re: How to connect my EBC (DaveF)
yeah, i noticed that, im getting used to it, at this point i do believe the head unit is broken. ill see what greddy has to say.
jdmcivic2fast
Sep 7, 2011 10:02 AM
jetspeedz
Aug 23, 2009 02:21 PM
underpressure02
May 13, 2008 07:52 AM
Jared
Sep 20, 2002 06:10 PM
technine
Jun 7, 2002 12:34 PM
