wastegate source after or before TB debate
Old Aug 23, 2009 | 10:53 AM
jetspeedz's Avatar
Default wastegate source after or before TB debate
Ive read up on this and like many other issues there are split decisions as so what is the way to go.
I have a TIAL WG and i have been reading they recommend the vacuum source before the TB so it only sees boost and no vacuum. Others say just run it the the vacuum manifold which is hooked up to the intake manifold which sees vac/boost.
So has anyone seen a torn or damaged Wastegate as a result of seeing vacuum? i can play it safe and just get one of these quick tap nipples but if it really does not matter for the sake of keeping all the vacuum lines neat and clean id like to use the manifold.
http://www.034motorsport.com/product...roducts_id=358
Thanks
Old Aug 23, 2009 | 11:06 AM
Turbo-LS's Avatar
Default Re: wastegate source after or before TB debate
You can run the pressure source to either the intake manifold or to the turbo. Yes tial recomends you dnt hook it up to a vacuum source only a pressure source but they work just fine that way.
Generally you will get a little less boost than your WG spring is rated at if you put the pressure course on the turbo. reason being is the intercooler (if you have a good one) will cause a little back pressure so less pressure comes out of it than going in IE if you have 9 psi going in you might only get 7.5psi out and thats teh amount of boost pressure your engine will see.
Now if you connect it to the intake manifold then you will see the full 9 psi of pressure because the WG isnt openign up till the manifold sees 9 psi and not the turbo seeing 9 psi. IE if your seeing 9 psi at the engine then your turbo is producing about 10.5-11 psi pre-intercooler
Old Aug 23, 2009 | 11:08 AM
jetspeedz's Avatar
Ok thanks for the response, ill put it on the vacuum manifold then which will be hooked up to the skunk2 PCV fitting.
thanks again
Old Aug 23, 2009 | 12:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
for the sake of consistency, and it is the way i have been doing it since 95 when working on the buicks, i source the boost reference off of the compressor housing.
explained above is perfect.
but in my personal exp, i think it is more consistent when you are getting the pressure from the source.
Old Aug 23, 2009 | 01:50 PM
jetspeedz's Avatar
I agree with you, but you have to wonder why so many others use the other source and don't have problems. On my bike i get the source right from the plenum which is before the TB.
Old Aug 23, 2009 | 01:59 PM
m R g S r's Avatar
I always hook it up to the intake manifold.
Old Aug 23, 2009 | 02:01 PM
jetspeedz's Avatar
Do you have a Tial WG?
Old Aug 23, 2009 | 02:14 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If you are worried about it install a check valve, then it will not see vacuum at the waste gate.
Old Aug 23, 2009 | 02:15 PM
jetspeedz's Avatar
not so much worried about it just want to do it correctly and if vacuum really damages then Tial WG then ill either run the check valve or find a way to get the source right off the compressor
Old Aug 23, 2009 | 02:21 PM
jetspeedz's Avatar
On another note the bottom barb on a Tial WG is that 1/4 opening for the vacuum hose?
trying to get all the other parts and small things like this ready so i don't have to make any more trips to a store. HKS Bov is 1/8th for anyone else wondering. and the Autometer electronic Sensor is 3/16
Luke G.
Sep 14, 2010 08:45 AM
chriskey0829
Feb 1, 2006 07:10 PM
SpOoNisMyFriEnD
Sep 15, 2005 07:53 PM
djnikko
Jan 13, 2004 07:49 AM
2muchPSI
Nov 22, 2003 02:34 PM
