LS/Vtec in a '93 Del Sol Si????
ok, I have a obd2 lsvtec motor and I want to swap it into my 93 del sol si. all I have right now is the motor (head, block, tranny, and sensors) where do I get the other parts needed for the swap, and what parts to I need????
axles, ecu, harness, obd1 conversion, linkage??????mounts???? I have no clue what I need if someone could help me that'd be great
ECU- Kenji. Axles- Hydro B-series. Mounts- 94+ Integra. Linkage- try to get one for what ever tranny you end up getting. OBDIItoI- Swap out your distributor for one thats OBDI and just use the Stock Del sol wiring harness.
Thats all I can think of right now.
damn! all that ****, I was told the following
1) Upper driverside mount for 94+ integra
2) del sol b series linkage
3) hydro b series axles
4) obd1 distributor
and to use stock del sol wiring harness and the stock p28 and throw in hondata
does that sound right?
4) obd1 distributor
what model is your del sol si? or dohc vtec? oh and do I need an obd1 distributor and where do I find the axles and shift linkage???
[Modified by Pinhead, 2:52 PM 7/22/2002]
cody_sandlin
Aug 9, 2013 05:19 AM
mikej94civex
Feb 10, 2010 03:27 AM
JDM CRX
Aug 29, 2003 06:12 AM
good info btw, I really appreciate it
