94 del SLO Si+ B18c5 = swap questions
alright, im doing a swap for my for my freind, he has a 94 del slo Si..
hes got an ITR swap(uninstalled), almost all, hes missing axles,**** linkage,ECU, mounts,wireing harness.
---my questions
1. what mounts does he need? all ITR or DEL sol B16
2. what axles? del sol B16 or any b series?
4. what wiring harness? he has his stocker and ITR
5. is there additional wiring on whatever harness is needed?
6. what ecu? rechip a P28 or what?
7. what shift linkage? del sol VTEC or any b-series?
8. did i miss anything?
thanks to all that respond, i know how to do all 88-91 ef swaps and 96-00 ek swaps, but the 92-95 area is what i dont know that much about. and if anyone has the parts needed, let me know ASAP we will buy. BTW also looking for a ITR flywheel. thanks t all that help/respond.!
---my questions
New User
Re: 94 del SLO Si+ B18c5 = swap questions (JDM CRX)
first its del sol...
the ITR ecu would work the best with the ITR motor
b series axles
del sol VTEC shift linkage
b series axles
Re: 94 del SLO Si+ B18c5 = swap questions (blkDOHCsol)
b series axles
b series axles
I don't think that the itr ecu will work. Plugs are different on the ecu.
I would just chip the p28 from the del sol. No additional wiring will be needed if he uses the p28 ecu.
Wiring harness from the itr engine(obd2) will plug into the wiring on the strut towers of the del sol(Obd1).
b series mounts, and axles, the intermediate shaft should be with the tranny if he gets the engine and tranny as a package.
Re: 94 del SLO Si+ B18c5 = swap questions (skunkwhat)
what about switching the car from obd1 to obd2 with the itr ecu and a adapter harness. i'm doing the same swap in a 93 sol si but since its a sohc vtec i will need to add wires for knock sensor and a few other things i beleive. i have the complete itr but i think i will need to buy the harness adapter and the shift linkage from a dohc sol. any other input is appreciated.
delsol_typer
13
02-21-2007 01:49 PM
