d16a6 into del sol help
Just a few quick questions, searching hasnt helped me much.
Im looking into buying a del sol si with a blown d16z6. I have a perfect d16a6 from my CRX that i could swap in. Keeping the del sol hydro trans, distributor, intake manifold, injectors. I do not want to do a mini me swap just run the a6 with obd1.
What will be needed to run the a6 in the del sol?
What ECU will i need?
Will I have any issues bc the car was originally vtec and this is a non vtec motor?
Re: d16a6 into del sol help
Use the del sol mounts
A p06 ecu will work fine with the motor. Can get a basemap added if you really wanted too but will run fine as is.
Dont know anything about the sensor plugs on an obd0 motor and a obd1 harness if its plug and play. Someone else needs to chime in on that one.
auburnBoy
05-05-2006 09:31 PM
Spool Me Up
09-13-2003 03:53 PM
