So after 5000 miles of being boosted i replaced the plugs... anyone want to give me input?
From: New York in the summer, South Carolina in the winter
The setup is a B20b low compression bone stock, with a 55 trim borg warner t3/to4e
running 10 pounds, tuned on crome pro by RLZ engineering-
I was curious, if anyone could take a look at the plugs after 5k miles and tell me how everything looks-
also, what is that yellowish color on the ceramic?
and there were little bits of stuff, it appeared to be anti seeze or something, but it was on the tip of the plug?
thanks!
thanks!
kinda hard to tell from your pictures but they look fairly normal i would say. I dont really see anything out of the ordinary. take pictures of all 4 where the side electrode (shaft) meets the plug itself. That way we can see how lean/rich each cylinder is running.
I don't see any detonation, but reading worn plugs is really not a good way to go about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">I don't see any detonation, but reading worn plugs is really not a good way to go about it.</TD></TR></TABLE>
Is there any other ways to make sure everythings 100%?
the vehicle runs 110%, no hickups or anything, but just want to make sure
How are you pulling the plugs? Right after a pull at full load and cutting off the ignition?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">How are you pulling the plugs? Right after a pull at full load and cutting off the ignition? </TD></TR></TABLE>
no- this is just after daily driving the vehicle/ 25 1/8th mile runs
ginahoy
Mar 9, 2016 11:28 AM
a1320honda
Sep 4, 2007 10:04 AM
