how my plugs look ????
Old May 29, 2006 | 05:45 PM
B18C1CYA's Avatar
Default how my plugs look ????
Here are my plugs , ran on vp c12 @30psi with a .016 gap , I think I was having spark blow out though , it has ben realy hot yestaerday and today ,
Old May 29, 2006 | 05:59 PM
Joseph Davis's Avatar
Default Re: how my plugs look ???? (B18C1CYA)
The right two look like they've seen coolant. Yellow/green glaze on the ceramic. Might just be heat discoloration.
Too many miles to get a decent read like you can on fresh plugs, but what I can make out of the heat mark on the ground strap on the second (from the left) looks good. If the threads are at all discolored, I am wrong - do I make out an "8" on that one plug... at 30 psi? What plugs are those?
The same (second) plug also looks like it has a tiny speck on it?? Maybe?
You can tell the first plug is running a bit richer by the soot in the well, but the ceramic is still clean so it's a transitory issue. How do you have your individual cylinder trims set?
Old May 29, 2006 | 06:40 PM
B18C1CYA's Avatar
Default Re: how my plugs look ???? (J. Davis)
yeah no coolant issues , and I dont have them in order , the one on the left end is cycl #3 so and from day one of haveing a stock motor they looked like that from #3 , also they are 8's NGK , I didnt tune my car , just mainly wanted to know how they looked from running on race gas (c12) , and the spekaled look is ash it comes off with your fingure think I should go to 7's on race gas ???? I was told it would not hurt to do so
Old May 29, 2006 | 07:19 PM
Plug selection is a wierd thing in JoeyWorld.
I've touched stock B16 with .50 T3/T04E @ 8 psi running 8's. Even after adjusting individual cylinder trims the #1 plug was super cold and looked like it would rather run a seven. #3 was full hot, discolored the first couple threads, wanted a freaking 9. #2 and #4 liked the 8's in the engine. Stock geometry LS/VTEC making 300 whp @ 12 psi, .57 trim T3/T04E, liked 7's. 2.0/VTEC, T67, 15 psi, overheated 8's and went straight to 10's because I had no 9's on hand... it likes them fine, they burn clean and don't foul.
Those look like R5671A-8. If you have more on hand, keep running them. If you have to buy them, get R5672A-8... the 2's stick the center electrode a little further out in the chamber which allows for better flame propigation on a turbo engine.
Anyway. Aside from the discoloration on the two rightmost plugs, which is probably due to mileage on them, I'm not seeing anything that makes me think you have a problem. If the threads aren't heat discolored I'd stick with the 8's. If you get a chance to get some big glossy pics before the plugs have 10 or so miles on them, do so. That's the prime time to read them.
ScottF
Feb 21, 2010 10:49 AM
NemesisCBR
Jan 22, 2009 08:36 PM
mickey513
Feb 23, 2004 05:41 PM
Floyd
Jun 18, 2002 01:35 AM
