B16b question
Old Jul 24, 2008 | 04:46 AM
WhiteEKgsr's Avatar
Default B16b question
Im thinking about buying a b16b shortblock with a apun bearing and i was woundering what crank and rods do the block use. Ive never heard of any such so do i just use b16 a internals thanks
Old Jul 24, 2008 | 02:02 PM
vtecb18c's Avatar
Default Re: B16b question (WhiteEKgsr)
no you use b16b internals which is CTR
Old Jul 25, 2008 | 02:35 AM
Extradition's Avatar
The b16b crankshaft is a special balanced crankshaft. The rods are slightly longer because the deckheight of the motor is the same as a GSR/Integra Type R. You'll need to use the stock B16b rods (B16a are much shorter) or buy aftermarket rods. The block is a Y block (Tall deck block) as opposed to the B16a/B17a block which is an A (short deck block). You might want to just strip out the internals and replace it with GSR (about $250 and a lot more Torque).
Old Nov 13, 2008 | 12:47 AM
turbo97coupe's Avatar
Default Re: B16b question (Extradition)
buy gsr block but make sure u use evey ctr head part cam and B16n P2P pisions and all that would be a sickk dd with a poor mans type r motor
mitchell_2kSiR
Mar 23, 2009 08:39 PM
Skunk2R
Dec 28, 2008 04:56 PM
gooseshit
Mar 15, 2007 10:24 AM
BLUE EH3
Oct 10, 2004 11:16 AM
sean
Sep 24, 2002 11:31 AM
