EJ6 B18C Swap Vtec Prob.
Old Jul 21, 2008 | 08:20 AM
98CivB18C's Avatar
Default EJ6 B18C Swap Vtec Prob.
Swapped a JDM B18C into my Ej6 DX Auto. Did the 5spd conversion. Problem is that my Vtec isnt working. I spoke with someone on the forums via AIM and he said that if it doesnt work since its a JDM motor the VTEC has 1 wire from the solenoid. Its just the Green Vtec wire. He mentioned something about me having to wire in the pressure switch. I used my STOCK dx auto wire harness. How can I get my VTEC working and how would I wire in the pressure switch when it only has 1 wire comming from the solenoid?
Old Jul 21, 2008 | 08:24 AM
Budget Racer's Avatar
Default Re: EJ6 B18C Swap Vtec Prob. (98CivB18C)
I think if you are running a USDM ECU that you would just need to change your V-tec switch to a 2 wire USDM one that will plug into the right places on the ECU.
Old Jul 21, 2008 | 08:26 AM
98CivB18C's Avatar
Default Re: EJ6 B18C Swap Vtec Prob. (Budget Racer)
I ordered everything from Hmotorsonline and it came with a JDM B18C and im guessing a JDM ECU?
-Justin-
Feb 29, 2016 05:07 AM
sammydigital
Jun 9, 2006 05:31 PM
mr. carpenter
May 5, 2004 09:47 PM
EKen9
Jul 4, 2002 07:18 PM
