turbo ef wont rev over 4000 rpms
Old Jul 18, 2008 | 06:51 AM
redflaredcrx90's Avatar
Default turbo ef wont rev over 4000 rpms
i have turbo 90 civic si hb. it was converted to obd 1 has a base map for the set up but wont rev over 4 grand. the ecu blinks code 14 but we have changed sensor. but still blinks code 14. the idal on the car dosent change its still a stedy flow. the plug for the tps sensor was damaged a lil bit but seemed ok. any input is needed
Old Jul 18, 2008 | 07:28 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: turbo ef wont rev over 4000 rpms (redflaredcrx90)
reving to 4k and the iac shouldnt be related unless you have something mis wired.
Old Jul 18, 2008 | 02:17 PM
Default Re: turbo ef wont rev over 4000 rpms (boostedcivicsir)
thats what i was thinking too i think the tps ia bad
Old Jul 18, 2008 | 04:43 PM
ringminion_blank's Avatar
This is unlikely but, is it possible your base map didn't get burned right? or maybe the chip got installed backwards, or not at all? Did you buy a jumper or make one?
from what I see when our cars go into limp mode it throws a soild CEL. I haven't seen a car yet that has gone into limp mode and been able to read a code. this is just me, im sure there are people out there that have.
FSUseminoleEM1
Feb 19, 2010 08:34 AM
getnasty
12
Oct 26, 2009 06:54 AM
Gant
May 17, 2005 08:02 AM
kaj
Sep 27, 2003 09:36 AM
synergy004
Jul 6, 2001 11:45 AM
