cylinder bore
Old Jul 17, 2008 | 11:51 AM
avotegra's Avatar
Default cylinder bore
which size cylinder bore can make more power.......have ge-sleeve block with std bore right now...........81.5, 82, 83 or 84..........
Old Jul 17, 2008 | 11:59 AM
chimmike's Avatar
generally speaking: 84mm
Old Jul 17, 2008 | 03:44 PM
Mikey3000's Avatar
Default Re: cylinder bore (avotegra)
ever heard the phrase: "no replacement for displacement" ? it's true.
Old Jul 18, 2008 | 02:47 AM
avotegra's Avatar
Default Re: cylinder bore (Mikey3000)
81.5 so i can bore out later when cylinder wall stratch.......good idea
Old Jul 18, 2008 | 03:14 AM
cjordan's Avatar
84.5mm
Old Jul 18, 2008 | 03:29 AM
avotegra's Avatar
Default Re: cylinder bore (cjordan)
should i get some arp main bolts or stock main bolts should be good enough.......
Old Jul 18, 2008 | 07:28 AM
Muckman's Avatar
Moderator in Chief
stock is fine. if you go with main studs the higher clamping force requries a line bore/hone to correct and that opens a whole can of worms.
Old Jul 18, 2008 | 01:05 PM
avotegra's Avatar
Default Re: cylinder bore (Muckman)
stock mean the one i took off the motor. can i reuse it......
Old Jul 18, 2008 | 04:59 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avotegra &raquo;</TD></TR><TR><TD CLASS="quote">stock mean the one i took off the motor. can i reuse it......</TD></TR></TABLE>
Yes,you can reuse the main bolts.They are not a week point in a b-series.The 81mm stock bore will be fine to start with.
dezerte
Feb 26, 2007 08:48 PM
Falken22
Nov 24, 2006 12:01 PM
mycrx7
Aug 10, 2005 02:41 PM
Gant
May 28, 2005 08:10 PM
