When breaking in a turbo motor do you.....
break it in WITH or W/O the turbo kit on there?
an how many miles do you break it in before you tune 1000-1500
this is a fully built and sleeved ls/vtec btw
I think most people break it in without boost. I believe you dont have to take the whole kit off, you can just take the spring out of the wastegate and it will let all the boost into the atmosphere. If I am way off base, someone please correct me.
it wont let boost in the atmosphere it will vent all the exhaust gases into the atmosphere. It will sound like complete ***.
y can't you just disconnect one of the charge pipes so there's a leak and no matter how hard u are on the throttle you wont get more the 1 lb. That way the exhaust gas still goes through the exhaust and doesn't smell like ****.
He just rebuilt his motor. Why the hell would he want to rebuild his turbo too??
And to answer your motor break in question:
I have this thread saved in my notepad--just because I too will soon need to break-in a new motor.
https://honda-tech.com/zerothread?id=214707
this isn't a race motor though, it will be daily driven (somewhat). the question is should I swap the full motor in, drive 1,000-1,500 miles and then slap on the turbo kit and tune? or have the turbo put before I swap the motor in there, and just boost Really low levels of boost drive 1k miles then tune it.
Hi Keith.. Build the motor to ur specs and do the swap. After 1000-1500 miles do the turbo kit.. Let me know if u need anything...
Sorry about that. I realized that was for a race motor after I posted.
If you search you might find some threads on it.. I thought I saved more topics on it, but I guess i didnt.
I would say that you could keep the turbo on, just no large amounts of boost for the first thousand miles.
Make sure that when breaking in that you dont keep a consistent engine speed (stay away from long highway cruises).
I remember someone stating that you should increase engine top speed every couple hunderd miles. Another words, dont take over 3k rpm for the first 300 miles. Then dont go over 3.5k rpm for the firt 400. Then 4.5k under 600. And so on.
I would introduce very small amounts boost to the motor around 750 miles. Just to let the rings seat under boost pressure while they are still being broken in under vacuum pressure conditions.
[Modified by 93LSivic, 4:50 PM 7/20/2002]
I break my motors in slow for the first few minutes. usually 20-30 mins into a breakin, i'm flooring it in 2 and 3'rd gears bringing it to redline, and letting the engine/car bring the revvs back down. Decelleration is important.
J1A1H
Apr 21, 2007 04:27 PM
rice a roni
May 18, 2006 07:01 PM
