crvtec-problems
Im using the 97b20 bottom end with b18c head. I dropped the compression to 9:1 and installed the block gurdle, but anyways..My problem is oil leaking from in between the head and block, where you plug the oil passage. Has anyone experienced this problem before??Does anyone know a possible solution to this. If I have to rip the head back off again Id like to know what to look for..
Thanks in advance
Jude Olwell
Thanks in advance
Jude Olwell
A fact that I have never seen posted, and rarely tell anyone myself. Is that the stock gasket has copper rivets holding it together. The one near the oil hole on the head needs to be removed. It gets in between head and deck and doesnt seal all the way. Good luck.
(sorry!)
anyways - head bolts? which ones did you use/re-use?
hopefully the GSR/B18C ones?
t..
Im using the ARP head studs..The head gasket Im using is the CRV headgasket from a 97', I believe. Would that problem with the rivets apply to me??Will this headgasket work for my application?Any suggestions would be appriciated..These are some good ideas thus far. I need to get this oil leak fixed b4 I put my turbo kit back on!!Thanks guys for the help
Jude Olwell
Jude Olwell
If you are using A GSR head on the CRV block, the oil leak may be caused by too much pressure build up in the crank case. When you use the GSR head and CRV bottom you eliminate the PCV valve and there is no venting for that pressure to vent out through. I ran into the same problem. I even had the internal VTEC oil line welded and shaved at a machine shop. What I did was drill a hole for a grommet on the valve cover. Then with a grommet in there i placed a PCV valve in the grommet and ran it into my Skunk 2 manifold. It doesn't totaly solve the problem but helps little.
-Steve-
-Steve-
ya.. I did the same thing I tapped the valve cover and ran lines into a catch can with a breather..SO I think (hope) that is taking care of the head pressure...
Jude Olwell
Jude Olwell
Corksil
Apr 29, 2011 11:15 PM
stadanko
Jul 21, 2009 04:08 PM
