Having issue with HONDATA S300.
Like the topic says,
I tried PMd Hondata forum.. NO help at all. anyways the problem is, somtimes I see Green and Red Light at the same time and I was not datalogging at all. Most of the time it is Solid green.
I know someone on here knows..
Please help thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">do you have an aftermarket ignition box mounted near it?</TD></TR></TABLE>
my aftermarket ignition box is in my engine bay.
[QUOTE=is your onboard dataloggin enable if so it might be activating with the setting you have in the software
[/QUOTE]
No on board dataloggin is disenabled.
[/QUOTE]
you can update your usb drivers first.
Look like you s300 can see your laptop so you have a problem with your connection i think...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flesh199 »</TD></TR><TR><TD CLASS="quote">you can update your usb drivers first.
Look like you s300 can see your laptop so you have a problem with your connection i think...</TD></TR></TABLE>
usb driver updated.
make good connection. still having green and red light at the same time.
usb driver updated.
i am having a similar problem but instead of green and red it changes to solid red from time to time... turn the car off and start it again and it is grean
I got that problem runs fine Intell I try too get on the the gas and let vtec open that red light light comes on so I let off it won't go away so I push the clutch in and car drops to ideal the red light goes away. So I give another pull in third and it comes on again so I let off it won't go away so I push in the clutch then back to ideal then back to green. Any info would help thanks guys.
