idle/leak problem help!!!
Old Jul 1, 2008 | 04:07 PM
Vt3c_eg's Avatar
Default idle/leak problem help!!!
okay so i own a 92 hatch with a d16z6 swap. my problem is that since i change my throttle body it idle from 2.5-3 rpm back and forth. if i open the throttle body a little bit it rev the motor all the way to redline and wont stop until i turn off the car. But if i cover the throttle body with my hands it goes back to normal, so i have a leak somewhere right? i never had that problem until i change the throttle body. i also change the gasket too! tighten every bolt tight and plug all the line in. please help vacuum line is plug in.
Old Jul 1, 2008 | 06:26 PM
Vt3c_eg's Avatar
Default Re: idle/leak problem help!!! (Vt3c_eg)
any one!?
Old Jul 2, 2008 | 04:10 AM
Vt3c_eg's Avatar
bump!
Old Jul 2, 2008 | 04:15 AM
Nbboy7's Avatar
is anything cracked did you try a lil silocone around the gasket. It might not fit flush.
Old Jul 2, 2008 | 04:37 AM
Vt3c_eg's Avatar
Default Re: (Nbboy7)
no crack and haven't tried silicon yet. maybe i should.
Old Jul 3, 2008 | 04:19 AM
Vt3c_eg's Avatar
Default Re: (Vt3c_eg)
just want to say it was the fitv (fast idle thermal valve). got it fix!
Old Jul 3, 2008 | 06:32 AM
90teg91hatch's Avatar
i dont know try switching your tps and map sensor plugs... maybe they are hooked up wrong...
Kustom X
Apr 3, 2012 07:21 PM
DO/\/\O
Jul 26, 2011 01:44 AM
majek
Jul 23, 2005 08:41 PM
NumberB
Jun 7, 2005 02:26 AM
CRX_Control
Nov 7, 2004 07:47 PM
