Lug nuts tight, wheel loose?
Old Jul 1, 2008 | 12:50 PM
jdmland's Avatar
Default Lug nuts tight, wheel loose?
everytime i let off the clutch i can hear a klunk,or when i brake hard or shift.
not the cv kind of klunk, nothing while turning so i rulled out the axel.
So i jack the car up, notice the tierod end boot is ripped to ****, but not the axle.
So i grabbed the driverside wheel and i seem to wiggle it a little,(same noise while all above stuff happens) passenger side seems nice and tight no wiggle, just the drivers, so i'm leaning towards the wheel bearing, but before i go and replace it, could possibly the tierod end be the prob?since i noticed the boot was all ripped to ****? i don't thing that would make the wheel wiggle a little when i pull on it, just wanna make sure.
Old Jul 1, 2008 | 01:09 PM
wastedyouth2542's Avatar
Default Re: Lug nuts tight, wheel loose? (jdmland)
probably the wheel bearing but not sure, im leaning toward wheel bearing tho good luck
Old Jul 1, 2008 | 03:42 PM
Jimmy's Avatar
Global Moderator
Wheel bearing..
Also replace the tie rod.
Old Jul 1, 2008 | 04:29 PM
steveo135's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearing..
Also replace the tie rod.</TD></TR></TABLE>
x2
Old Jul 1, 2008 | 05:01 PM
SuckMyDOHC's Avatar
Default Re: (steveo135)
x3
Old Jul 1, 2008 | 05:25 PM
butand50's Avatar
Default Re: (SuckMyDOHC)
ahh fork it.... x4
Old Jul 1, 2008 | 06:24 PM
jdmland's Avatar
Default Re: (butand50)
Found the problem, upper ball joint, when push down on the upper control arm i hear a clunk, plus it seems loose.
Now replacement balljoints are insane prices, does anybody know of a cheap place to pic one up at?, possibly get a universal one?
autozone dosne't list just the ball joint, i heard napa has universal ones that will work ,anybody?
I'm not about to buy the complete upper control arm.
Old Jul 1, 2008 | 06:35 PM
Jimmy's Avatar
Global Moderator
Default Re: (jdmland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland &raquo;</TD></TR><TR><TD CLASS="quote">Found the problem, upper ball joint, when push down on the upper control arm i hear a clunk, plus it seems loose.
If you really think that is the issue.. you can buy just the balljoint from acura.. or where ever..
but i wouldn't recommend you beating it out.. Take the upper control arm off and take is to a shop and have them press it.. or press it yourself if you have access..
Old Jul 1, 2008 | 06:40 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Jimmy)
Acura doesn't sell upper balljoints, just lower. You have to buy the whole upper control arm from them.
Old Jul 1, 2008 | 06:58 PM
Jimmy's Avatar
Global Moderator
Default Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Acura doesn't sell upper balljoints, just lower. You have to buy the whole upper control arm from them.</TD></TR></TABLE>
Your right..
http://www.acuraoemparts.com/d...ch=no
That sucks.
To the OP.. Call up the local parts stores.. or just buy the whole upper control arm.. Now would be a good time to get a good omnipower or skunk 2 front camber kit
Old Jul 1, 2008 | 07:48 PM
jdmland's Avatar
Default Re: (Jimmy)
this should work
http://www.partsamerica.com/pr...Set=A
Unphzd
Dec 17, 2010 01:10 PM
Tim2179
Jul 13, 2005 01:13 PM
DCbb6
Oct 8, 2003 05:39 PM
Spade
Aug 7, 2002 02:54 PM
DavidGSR
Aug 20, 2001 10:53 AM
