Lug nuts tight, wheel loose?
everytime i let off the clutch i can hear a klunk,or when i brake hard or shift.
not the cv kind of klunk, nothing while turning so i rulled out the axel. So i jack the car up, notice the tierod end boot is ripped to shit, but not the axle. So i grabbed the driverside wheel and i seem to wiggle it a little,(same noise while all above stuff happens) passenger side seems nice and tight no wiggle, just the drivers, so i'm leaning towards the wheel bearing, but before i go and replace it, could possibly the tierod end be the prob?since i noticed the boot was all ripped to shit? i don't thing that would make the wheel wiggle a little when i pull on it, just wanna make sure. |
Re: Lug nuts tight, wheel loose? (jdmland)
probably the wheel bearing but not sure, im leaning toward wheel bearing tho good luck
Wheel bearing..
Also replace the tie rod. |
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Wheel bearing..
Also replace the tie rod.</TD></TR></TABLE> x2 |
Re: (steveo135)
x3
Re: (SuckMyDOHC)
ahh fork it.... x4
Re: (butand50)
Found the problem, upper ball joint, when push down on the upper control arm i hear a clunk, plus it seems loose.
Now replacement balljoints are insane prices, does anybody know of a cheap place to pic one up at?, possibly get a universal one? autozone dosne't list just the ball joint, i heard napa has universal ones that will work ,anybody? I'm not about to buy the complete upper control arm. |
Re: (jdmland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland »</TD></TR><TR><TD CLASS="quote">Found the problem, upper ball joint, when push down on the upper control arm i hear a clunk, plus it seems loose.
Now replacement balljoints are insane prices, does anybody know of a cheap place to pic one up at?, possibly get a universal one? autozone dosne't list just the ball joint, i heard napa has universal ones that will work ,anybody? I'm not about to buy the complete upper control arm. </TD></TR></TABLE> If you really think that is the issue.. you can buy just the balljoint from acura.. or where ever.. but i wouldn't recommend you beating it out.. Take the upper control arm off and take is to a shop and have them press it.. or press it yourself if you have access.. |
Re: (Jimmy)
If you really think that is the issue.. you can buy just the balljoint from acura.. or where ever.. but i wouldn't recommend you beating it out.. Take the upper control arm off and take is to a shop and have them press it.. or press it yourself if you have access.. </TD></TR></TABLE> Acura doesn't sell upper balljoints, just lower. You have to buy the whole upper control arm from them. |
Re: (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
Acura doesn't sell upper balljoints, just lower. You have to buy the whole upper control arm from them.</TD></TR></TABLE> Your right.. http://www.acuraoemparts.com/d...ch=no That sucks. To the OP.. Call up the local parts stores.. or just buy the whole upper control arm.. Now would be a good time to get a good omnipower or skunk 2 front camber kit https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: (Jimmy)
this should work
http://www.partsamerica.com/pr...Set=A |
