I need some help on B20vtec?
Old Jul 18, 2002 | 01:44 PM
MysteryWagon's Avatar
Default I need some help on B20vtec?
I need a good web site or information on how to do this. i want to build a b20 block for FI I just don't know to much about the conversion. I have a B16 in my car now I just need to know how to do the rest. I will purchase the block as soon as possible so if I could get any information I would appriciate it.
also what things wil be needed. like timming belt alt. belt. what should I upgrade to make this a safe motor for high boost around 18 lbs.
well give it to me tech peeps
justin
Old Jul 18, 2002 | 07:50 PM
tinkerbell's Avatar
Default Re: I need some help on B20vtec? (MysteryWagon)
https://honda-tech.com/zerosearch
search parameters include Frankenstein, CRV, CRVTEC, B20VTEC B20B, B20Z, boost, turbo...
also try:
www.google.com using the above terms...
there hasnt been heaps here on boosted B20 conversions, but im sure its been done with great success...
t..
Old Jul 18, 2002 | 08:46 PM
jdmillusion's Avatar
crvtec.com, c-speedracing.com. those are only 2 sites off the top of my head, and oh yes, of course, hybrid.honda-perf.org
on the same note, a few of my friends have been encouraging me to get the b20b over the z, how so? i don't wanna bother them right now, casue we're having conflicts. thanx techies.
Old Jul 18, 2002 | 08:50 PM
tinkerbell's Avatar
Default Re: I need some help on B20vtec? (jdmillusion)
if you are planning boost on stock internals - the lower CR of the B20B is better ie. 8.8:1 VS 9.6:1
if you going to replace stuff, the blocks are the same...
Old Jul 19, 2002 | 02:51 AM
kinesistech's Avatar
The most important work needs to be done to the head. As for parts, i would use obd2 gsr or itr oil pump, they have better volume flow. Same goes for water pump and T belt for that matter. If you use dohc vtec pumps you need dohc belt, with nonvtec pumps, non vtec belt.
Not only is b20b lower compression, but at higher rpm, there can be valve conflict with b20z and vtec valves. Some jdm b20b's are high compression. Also consider increasing fuel pressure a few psi. If you want to boost 18psi I would get new pistons and engine management. I think 18 is a lot for a stock block. Plus then you can boost 25.
Old Jul 22, 2002 | 08:51 AM
Default Re: I need some help on B20vtec? (kinesistech)
if i plan to boost, i don't think i'll boost more than 15, that's just me. thanx kinesis, and techies. and you also mentioned, "some b20b's are high compression"? for what instance?
Old Jul 22, 2002 | 11:58 AM
Jeff C's Avatar
no, he said "some JDM b20b's are high compression
the jdm b20b is the same as the usdm b20z which is they both have 9.6:1 compression
for what instance?
what are you asking here
[Modified by Jeff C, 3:59 PM 7/22/2002]
Old Jul 22, 2002 | 12:01 PM
Default Re: I need some help on B20vtec? (Jeff C)
i see, thanx jeff. clearly noted.
Old Jul 22, 2002 | 01:53 PM
thanks for the help guys
another question??? what is the estimated power a b20b with B16 head and low compression going to make, I am talking motor only 9.0 CR and B16 head before being boosted. Is the block really strong enough for that much boost, and yes I am planning on going with an autronic standalone.
Justin
Old Jul 22, 2002 | 02:02 PM
Default Re: I need some help on B20vtec? (tinkerbell)
specifically my friend's b20b turbo. i have neither specs from him, nor timeslips. i can't judge, i'm sure a good run can lead up to 12's.
Old Jul 22, 2002 | 05:33 PM
tinkerbell's Avatar
Jeff, how do you tell which JDM B20B's are 9.6:1 CR?
thanks,
t..
Old Jul 22, 2002 | 07:56 PM
Ri5e's Avatar
All the JDM B20Bs are 9.6:1 compression. I've checked JDM B20B's piston head is more flatter, just like its USDM B20Z brother. The USDM B20B, the piston head curves more.
Old Jul 22, 2002 | 08:51 PM
tinkerbell's Avatar
Default Re: I need some help on B20vtec? (BG Boost)
tell me about the piston stamps?
have you seen them? what stamp is on the JDM B20B pistons?
thanks!
t..
Old Jul 22, 2002 | 11:50 PM
b20z is PHK. Its probably the same.
Old Jul 23, 2002 | 03:19 AM
Jeff C's Avatar
i am pretty sure all jdm b20b are the same, i was just correcting he quotes when i used "some"
i have have only seen usdm b20b pistons. not sure of the stamp for these off the top of my head, but they have a "dish" shape to them kinda like a cereal bowl that is why i ditched them in the beginning
Old Jul 23, 2002 | 04:08 AM
tinkerbell's Avatar
my JDM B20B (head stamp 96) has p3f pistons...
ie low compression
and they are about 1mm dished - like Jeff says...
"i think only 98+ JDM B20B's have high compression pistons..."
t..
Rex-2000
Dec 3, 2014 04:35 PM
joread22
May 18, 2011 06:43 PM
mysterysktr7
Apr 23, 2009 07:51 PM
eats06702
Mar 23, 2008 12:12 PM
