Whats the easiest way to replace rings??
Old Jul 18, 2002 | 10:20 AM
ScrapinSi's Avatar
Default Whats the easiest way to replace rings??
It appears as though i have bad oil rings... what are the easiest ways to replace it? Yank the whole motor? or can i drop the pan, yank the crank, and pull them out from underneath, replace them, and reinstall them?
Old Jul 18, 2002 | 11:04 AM
4gvtec's Avatar
Default Re: Whats the easiest way to replace rings?? (ScrapinSi)
i pulled the head ,took off the oil pan.then unbolted one connecting rod at a time and pushed on the rod till the piston come out the top.put the bearings back in the same way the come out.like one one on the rod and the one on the cap.
i did it with the crank still in it.
[Modified by 4gvtec, 8:04 PM 7/18/2002]
Old Jul 18, 2002 | 11:08 AM
ScrapinSi's Avatar
Default Re: Whats the easiest way to replace rings?? (4gvtec)
oooh... never thought about trying that... i wont even have to pull the piston off the rods... hmmm... might have to try that out...
Old Jul 18, 2002 | 11:11 AM
4gvtec's Avatar
nope, keep the pistons on the rods.when you put the piston back in,MAKE SURE THE CRANK JOURNAL IS ALL THE WAY DOWN,SO THE CONNECTING ROD STUDS DONT HIT IT.
Old Jul 18, 2002 | 12:49 PM
ScrapinSi's Avatar
Why? is it bad if i knick the crankshaft? hehehehehehe
Old Jul 18, 2002 | 12:51 PM
kinesistech's Avatar
Take a piece of hose and put it over the studs to protect the crank.
How is it that you determined that you have bad oil rings?
Old Jul 18, 2002 | 03:09 PM
ScrapinSi's Avatar
Default Re: Whats the easiest way to replace rings?? (kinesistech)
When at WOT anything in vtec, my car BLOWS black smoke, smells like oil... when i drive my car normally, i can pull up to a stoplight and smell oil burning... Under normal driving, no smoke though... only under high revs... I've also noticed a power loss... I was thinkin burnt valve, but that would cause sloppy idle... i was also thinking oil seals, but that would smoke at startup...
dcintegradc20
Mar 9, 2010 09:04 PM
eg_gsr11
Mar 5, 2006 04:27 PM
hatchedzex
Oct 4, 2004 11:40 AM
sodacan33
Jun 10, 2004 07:10 AM
lucas569
Aug 10, 2002 10:47 AM
