Heavy oil blowback on Ls turbo.....is it normal?
Old Jul 18, 2002 | 08:02 AM
HybridCoupe's Avatar
Default Heavy oil blowback on Ls turbo.....is it normal?
I have 95ls turbo and my blowback on the valvecover is always covered in oil and is getting all over my intake manifold turning it a copper color from the oil....is it normal or is something wrong?
Old Jul 18, 2002 | 08:30 AM
Ri5e's Avatar
Default Re: Heavy oil blowback on Ls turbo.....is it normal? (HybridCoupe)
Blowby gas....Sounds like a broken ring land or broken ring top. Does smoke/oil puff from the breather valve on the valve cover?
Old Jul 18, 2002 | 08:37 AM
PrecisionH23a's Avatar
Default Re: Heavy oil blowback on Ls turbo.....is it normal? (BG Boost)
yea dude.... broken ringland sounds like your problem.
Old Jul 18, 2002 | 08:44 AM
Ri5e's Avatar
Default Re: Heavy oil blowback on Ls turbo.....is it normal? (GudeH23a)
Also, is your car hard to start up sometimes or sometimes it just stalls out while you cruise/brake to 0 mph?
Old Jul 18, 2002 | 09:23 AM
there is no smoke it just has oil on the filter on the valve cover...car runs strong and doesnt smoke at all...couldnt it be the pcv valve on the intake manifold that regulates oil?
also my compression is 190 per cylinder....
Old Jul 18, 2002 | 10:12 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
That happened to me 3 months ago. I know exactly what happened. IT is your head gasket. around one of your cylinders the ring of the head gasket couldn't take that boost that you were boosted and bamm you blew a head gasket like i did. BUt mine was worst. I had oil all over the hood engine bay, shooting out the pcv valve hole. I attached a hose around the air breather to stop the oil for shooting. THe next day i still went to the imstar racing event and came back home in 6th place.
Oh well.
Old Jul 18, 2002 | 10:20 AM
B20T's Avatar
thats normal mine does it to. need a catch can
B20 vtec 360hp@10psi pump gas and goodys
Old Jul 18, 2002 | 10:28 AM
brcivic411's Avatar
Default Re: Heavy oil blowback on Ls turbo.....is it normal? (B20T)
make sure you don't have too much oil in your system either
Old Jul 18, 2002 | 10:51 AM
KoRE's Avatar
mine is doing that but i have smoke also so i bought new pistons and rings and i'm now about to buy a new clutch and rods and replace the head gasket i say you might as well build it if your gonna have it apart like that.....
lovelove
Feb 10, 2009 06:39 PM
EkFG
Mar 15, 2008 07:47 PM
BigC-ivic
Aug 27, 2005 07:53 AM
Layziebtnh055
Apr 28, 2004 08:38 AM
KillerBee18
Sep 28, 2003 08:49 AM
