Which HKS Turbo ?
i was checking into the garret t30, but viren put me on to the hks dual ball bearing turbos...im running a fully built h22, and am looking for something around 15psi daily and 20-23 at the track, but im clueless when it comes to these hks turbos, there are so many different numbers and ****..2835 3040..etc etc....which one do you guys reccomend that would be somewhat like the t30 or a t3/t4e ball bearing, i want quick spool up, and the hks turbos are nice because they are also water cooled so i have no need for turbo timer...
thanks for the help....
The Garrett GT30 is an awesome turbo. Here are the specs I would go with the Garrett 705867-0002. Here are the specs:
T04S
.70 A/R Compressor Housing
56 Trim Compressor
T3
.82 A/R Turbine Housing
84 Trim Turbine
This turbo can easily support 500-550 whp adn it will have quick spool up time. HKS doesn't make a T3 based turbo that even comes close to these specs. Most of the HKS turbos are T25/T28 based turbine housings.
T04S
56 Trim Compressor
T3
84 Trim Turbine
.... and I believe the GT30 does come with a water cooled inner jacket?!?
that is also an option, at no additional charge
why wouldnt you want this option, this means no use of a turbo timer ?
The GT30 that I gave you a part number for is setup for an external wastegate. It does have a water cooled center section. Some people don't run water. I don't run water through my turbo and it is fine.
acy76
Dec 28, 2005 07:33 AM
