overheating!!!
Old Jun 23, 2008 | 03:29 PM
93delsolrunner's Avatar
Default overheating!!!
i have a 93 del sol and it started overheating today and i have plenty of coolant.... i really need to know where and how to check the thermostat and water pump??
Old Jun 23, 2008 | 03:54 PM
EcivicG's Avatar
Default Re: overheating!!! (93delsolrunner)
did it just overheat out of no where?
have you been hearing any weird noises lately?
what engine do you have?
when my pump went out, a couple days before, it started making some clunking noises. 2 days later it started to get hot then i figured it was that and replaced it.
Old Jun 23, 2008 | 04:05 PM
Default Re: overheating!!! (EcivicG)
its the 1.5 stock and i haven't heard any noises
Old Jun 23, 2008 | 05:00 PM
fastrc2's Avatar
if your water pump is still circulating coolant, then when you turn the heat on, the heat will be hot. if the thermostat is the issue, then the fan will turn on, but most likely the air its blowing out of the radiator wont be hot. i have seen a lazy thermostat, that still opened, but when the engine got hotter from high rpms,, it would react soon enough, i would start wit h the t-stat
nicanbeastfool
Aug 20, 2014 10:04 AM
HiChanDC2R
Aug 15, 2010 05:15 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
chuisek9
May 9, 2008 06:08 AM
christiian
18
Jul 16, 2006 12:03 AM
