Overheating... New water pump, thermostat, etc... What could it be?
Hey everyone.
My car is trying to overheat... sometimes.
I can't really pinpoint what exactly is triggering it. It almost seems to be doing it after a certain amount of time and then if I downshift and drive it harder, it settles down. If I cruise along at 55mph in 5th gear, i'm fine. If it sits at idle it SLOWLY rises. I mean, after 5 minutes it'll be somewhere between half way and 3/4.
I just replaced the water pump and thermostat(which was checked in boiling water) 2 days ago.
Radiator is just a few months old.
The fan is kicking on.
What else could be causing the car to WANT to run hot?
Blown headgasket? There's no serious amount of smoke to be seen... No boiling coolant. No coolant overflowing into the overflow can. Nothing.
Any ideas?
Any ideas?
I've let the car run and run with the radiator cap off... probably 45 minutes. Fan would NEVER come on. I stood there FOREVER!? Fan wouldn't come on.
So, I put the cap on... drove down the road. Fan came on. Took the cap off... topped it off, let it run for like 20 minutes still wouldn't come on.
Figured it was good enough?
How should I bleed the air out? I don't have an air release valve or anything. It's a d16z6
Is your thermostat OEM?
The procedure for bleeding air from a 92-95 Civic is here: http://media.honda.co.uk/car/owner/m...l/pdf/10-4.pdf
Also... I glanced at that pdf link. My car doesn't seem to have a bleeder bolt. My old d15 did... my d16z6 doesn't have one.
How is the process different if I dont' have one?
Just leave the cap off and run the car until the fan turns on? OR should I put the cap on half way like that pdf says?
But all bets are off AFAIC without an OEM thermostat.
Are you losing coolant and so adding it regularly?
Did you have this problem prior to replacing the thermostat and water pump?
I had the same problem I have right now.
It would overheat at idle. If I reved it way up and kept it there; the temp would go back to normal. Back to idle, or low rpm cruising it would steadily climb.
So; I replaced the thermostat and water pump.
Still doing the same thing!
Thermostat or head gasket or, with luck, too much air in the system. I lean towards head gasket right now. Sorry.
I've been worried that's what it is.
Hate hate replacing headgaskets. Especially in the winter with no garage.
I figured wind speed would cool the engine temp a bit.
When I say downshifting and increasing rpms would lower the temp gauge; even if I stayed at the same speed, and JUST downshifted... only change being rpms, the gauge would go down.
Don't know... i'll try bleeding it again before I change the HG
UltimX
12
01-18-2007 03:18 PM
