horror stories with eagle crank's.
Old Jun 17, 2008 | 04:32 AM
delsol vti's Avatar
Default horror stories with eagle crank's?
I have heard some stories where these crankshafts hold the rod bearings when using it in high rpm aplicattion's.
is it true?
I ask this because i bought one eagle crank and I am afraid to use it.
Old Jun 17, 2008 | 06:14 AM
Lubo_25's Avatar
Default Re: horror stories with eagle crank's? (delsol vti)
let me just say that they dont have honda consistencies...
Old Jun 17, 2008 | 09:51 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: horror stories with eagle crank's? (Lubo_25)
Lots of guys on H-T run 92mm cranks with no problem and I know at least a few of them are Eagle. I wouldn't worry too much about it. Just make sure your machine shop balances your bottom end.
Old Jun 17, 2008 | 10:36 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol vti &raquo;</TD></TR><TR><TD CLASS="quote">I have heard some stories where these crankshafts hold the rod bearings when using it in high rpm aplicattion's.
is it true?
if you run into this kind of problem then you need to go to a different engine builder
Old Jun 17, 2008 | 11:27 AM
JakeSpec's Avatar
Eagle Cranks
start with a fresh Mic'n for Bearings
Old Jun 17, 2008 | 02:05 PM
delsol vti's Avatar
Default Re: horror stories with eagle crank's? (2LEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Lots of guys on H-T run 92mm cranks with no problem and I know at least a few of them are Eagle. I wouldn't worry too much about it. Just make sure your machine shop balances your bottom end. </TD></TR></TABLE>
the crank is already balanced <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck &raquo;</TD></TR><TR><TD CLASS="quote">
if you run into this kind of problem then you need to go to a different engine builder </TD></TR></TABLE>
i´m the engine builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote">Eagle Cranks
start with a fresh Mic'n for Bearings </TD></TR></TABLE>
what is fresh mic'n? sorry but i don't undersantd all the wordz, i'm portuguese.
thanks, i see that eagle is a good brand for crank's, and good price/quality.
thanks for all replys.
Old Jun 18, 2008 | 08:54 AM
JakeSpec's Avatar
Buy Mutitoyo Snap Guage or Inner Bore Dial Guage to measure Journals and a 2-3 Inch Micrometer
you need to measure your journals and bores to determine your bearing color there are no more honda codes when dealing with eagle cranks
if you never used these tools you might want to take your crank and block to a good machine shop and see how much they will charge you to measure and logg all your journals and bores
remember eagle rods for LS/b20's are #3' bore on the honda chart for b16's or b18c1-5 they are # 2 bore on the chart
pm me i will try to help as much as i can.
Dont be scared of horror storys they are 99% Builder error lol dont hold me tt that ! haha
good luck
Old Jun 19, 2008 | 03:18 PM
Si91CRX's Avatar
Eagle cranks are the shiz!!
Bc3
Dec 26, 2006 11:35 AM
Radyjr
11
May 23, 2005 09:11 PM
hman09
Apr 17, 2004 07:37 PM
EKweezy
Oct 8, 2003 10:09 AM
paulzy
Dec 22, 2001 10:41 AM
