Eagle rods
Old Dec 25, 2006 | 08:12 AM
Bc3's Avatar
Bc3
Default Eagle rods
Hi
i bout eagle rods made for b16a2 and bout ACL rod bearings but when i put i on its moving 0,5mm to the sides, is that normal :S
Alli
Old Dec 25, 2006 | 09:08 AM
Snafubmx234's Avatar
Default Re: Eagle rods (Bc3)
That's not good. You need to use plastigauge and make sure you have the correct bearings.
Old Dec 25, 2006 | 10:17 AM
s2kdre's Avatar
Default Re: Eagle rods (Snafubmx234)
use oem ones. acl are one size i think.
Old Dec 25, 2006 | 11:39 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bc3 &raquo;</TD></TR><TR><TD CLASS="quote">Hi
Alli</TD></TR></TABLE>
Axial or radial movement?
Old Dec 25, 2006 | 12:29 PM
Ruben19's Avatar
i think is talking about the thrust washers.
if you dont have this, your crank will move side to side.
Old Dec 25, 2006 | 01:14 PM
Bc3's Avatar
Bc3
Default Re: Eagle rods (nfn15037)
sorry what do you mean ? i dont speak very good english hehe
i just put the rod´s on the crank and was checking if it was moving
Old Dec 25, 2006 | 01:15 PM
Bc3's Avatar
Bc3
Default Re: (Ruben19)
the crank is not on the motor and yes i have the washers :D
Old Dec 25, 2006 | 01:48 PM
DRAGLS's Avatar
Default Re: (Bc3)
yes that is ok.
Old Dec 25, 2006 | 01:54 PM
non-VTEC's Avatar
there is always a little side to side play once the rod is installed onto the crank.
if you look in the service manual there is a spec.
Old Dec 25, 2006 | 02:02 PM
Pondus's Avatar
Default Re: Eagle rods (non-VTEC)
Rod end play is supposed to be between 0.15-0.30mm for a B18C, with a service limit of 0.40mm. I'd think the B16A2 specs will be close/or same.
Old Dec 25, 2006 | 04:31 PM
eg:R's Avatar
i have the same problem you did also but on an ls block. i thought the rods maybe thinner but measure to be the same as stock rods. i remember measuring the specs and it had way more clearance
Old Dec 26, 2006 | 03:43 AM
Bc3's Avatar
Bc3
Default Re: (eg:R)
is your motor ok now?
Old Dec 26, 2006 | 09:07 AM
agrn93ls's Avatar
Default Re: (Bc3)
once assembled they will move less, the pistons will help keep them centered. its ok.
Old Dec 26, 2006 | 09:39 AM
Hybrid96EK's Avatar
Default Re: Eagle rods (s2kdre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">use oem ones. acl are one size i think.</TD></TR></TABLE>
Typical response. People have no clue what they are responding to, but they are always quick to blame the ACLs around this place. Too much OEM bearing bandwagon riders around here.
And just so you know, ACL's are available in three sizes. I have never had an issue with durability or clearances using ACL bearings.
Old Dec 26, 2006 | 09:40 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bc3 &raquo;</TD></TR><TR><TD CLASS="quote">sorry what do you mean ? i dont speak very good english hehe
Did you put the rods on WITH the bearings installed or without the bearings installed? I certainly hope you didn't put them on with the bearings installed and then moved them side to side dry. If so, you can pretty much write those bearings off.
Old Dec 26, 2006 | 11:09 AM
Bc3's Avatar
Bc3
Default Re: Eagle rods (Hybrid93Eg)
i put the bearing on the rod and what do you mean dry? my crank is covered in oil so it will not rust :S
(the crank on the pic is not my crank)
Old Dec 26, 2006 | 11:26 AM
eg:R's Avatar
Default Re: (Bc3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bc3 &raquo;</TD></TR><TR><TD CLASS="quote">is your motor ok now?</TD></TR></TABLE>
i hate my motor, it make to much noise on cold morning start. after warmup it make a very light tap in the block if you listen very carefully. motor is still running and been through many dyno passes.
Old Dec 26, 2006 | 11:35 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bc3 &raquo;</TD></TR><TR><TD CLASS="quote">i put the bearing on the rod and what do you mean dry? my crank is covered in oil so it will not rust :S
(the crank on the pic is not my crank)</TD></TR></TABLE>
Dry and in no assembly lube. You should have wiped it clean also since the oil will attract dust/dirt which will not be good for the bearings.
2BFI
Feb 11, 2006 08:43 PM
nicklk
Feb 9, 2004 06:41 PM
mattjohnston
Dec 9, 2003 03:35 PM
Killer_B
Jun 25, 2003 11:06 AM
paulzy
Dec 22, 2001 10:41 AM
