Car start and dies!!!!!HELP
Old Jun 11, 2008 | 03:47 PM
denso's Avatar
Default Car start and dies!!!!!HELP
the car i have is a 92 civic si... having problem....sometimes it start up and dies...i recently got a new starter and distributor and then the problem went away and came back....now my brother thinks it is the main rely.....so i went to the junkyard and pick one up and replace it....then....wow it started.!!!but the sad thing was it died afterward....and now i replaced with the old rely and started...and it stay on for a while...so i turn it off for 15 to 10 mins and turn it back on...then it work and it would die about a min later....what else can it be?????sorry for the long post but what else can it be the ECU?????? thanks
Modified by denso at 6:31 PM 6/11/2008
Old Jun 11, 2008 | 03:52 PM
z6hatchboy's Avatar
Default Re: Car start and dies!!!!!HELP (denso)
You might want to check the timing, and possibly do a valve lash adjustment. I had a similar problem once, it would start and sound like it had a cam and in a few minutes would die, but that was my problem. Do you have any cel's?
Old Jun 11, 2008 | 04:26 PM
96civic_hb's Avatar
That's hard to read..
Old Jun 11, 2008 | 04:40 PM
mohater's Avatar
Have you ever cleaned your IACV? That did wonders on keeping my 97 from stalling out while idle.
Old Jun 11, 2008 | 05:21 PM
denso's Avatar
Default Re: Car start and dies!!!!!HELP (z6hatchboy)
hey what do you mean by cel's?? thanks
Old Jun 11, 2008 | 05:24 PM
96civic_hb's Avatar
cel= Check engine light
Old Jun 11, 2008 | 05:33 PM
denso's Avatar
Default Re: Car start and dies!!!!!HELP (96civic_hb)
nope no check engine light.....
Old Jun 11, 2008 | 05:54 PM
hondafaneg6's Avatar
yeah check ur timing. did it run fine before? if u play with the gas will it stay running or shut off right away?
Old Jun 11, 2008 | 05:57 PM
instructor74's Avatar
You replaced the main relay with one from a salvage yeard did you open either one up and check for bad solder connections?
https://honda-tech.com/zerothread?id=1553252
Old Jun 12, 2008 | 06:34 AM
denso's Avatar
Default Re: Car start and dies!!!!!HELP (hondafaneg6)
it ran before.....and the distributor is set.....but yea when the car starts and when i gas it....it would die sometimes and sometimes when i gas it....it would be fine.......so i dont know...thanks...could it be that im not getting enough gas??? thanks
Old Jun 12, 2008 | 06:42 AM
blk96coup's Avatar
I would put some fresh gas in it and change the fuel filter. Then check you IACV like said above.
albert7
29
Feb 7, 2017 03:12 PM
djw19842005
Apr 15, 2010 08:11 PM
BLU CIVIC
Jun 22, 2008 04:08 PM
Si-Luden92
Jul 7, 2004 01:02 PM
Jet Black
Sep 10, 2003 07:07 PM
