Starting problem
Old Apr 12, 2010 | 11:10 PM
djw19842005's Avatar
Icon2 Starting problem
ya bro definitly a good buy "bang for buck" i got a small problem right now with starting that you may have an idea how to fix? i get a really ruff hot start every once and a while. it will start then but bogg out. for example i drive about 10 miles to the gas station then shut the car off. starts up fine. then i drive about a mile to the liquor store and it won't start just boggs out on me... after i sit and wait for about 10 min the car will then start? any ideas?
Old Apr 12, 2010 | 11:15 PM
Default I Can Not Figure Out This Hot Problem...
i got a small problem right now with starting that you guys may have an idea how to fix? i get a really ruff hot start every once and a while. it will start then but bogg out. for example i drive about 10 miles to the gas station then shut the car off. starts up fine. then i drive about a mile to the liquor store and it won't start just boggs out on me... after i sit and wait for about 10 min the car will then start? any ideas?
Old Apr 12, 2010 | 11:37 PM
vtaker's Avatar
Default Re: I Can Not Figure Out This Hot Problem...
Check the timing.
Old Apr 13, 2010 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
coil or ignitor in the distributor
http://techauto.awardspace.com/ignition.html
Old Apr 14, 2010 | 09:38 AM
twentyhurtz's Avatar
i say check coil/dizzy as well, most problems due to heat are electrical related, and the time you cool down, resistances drop and allow the electronics to function normally again.. something is just going out probably.
Old Apr 14, 2010 | 09:41 AM
dudesitsjdm's Avatar
that and check just to see if you are running rich wouldnt hurt to check.
Old Apr 14, 2010 | 05:19 PM
91akira's Avatar
Default Re: Starting problem
hmmm... that sounds like an MFR problem.
Old Apr 15, 2010 | 08:11 PM
Honda_ThuGZ's Avatar
x2
F20b97AccordLx
Jan 16, 2023 10:15 AM
E Swift
Jul 10, 2019 03:46 PM
EFEvedell
11
Dec 1, 2011 09:47 AM
grantbrott
Classic Hondas
Nov 18, 2010 01:19 AM
