hondata help
Old Jun 8, 2008 | 05:12 PM
1greatEG's Avatar
Default hondata help
so i took my car to get tuned. plugged in the new p72 with hondata i threw a CEL and would only rev to 4500 rpm then my tuner said that hondata could not connect to his computer. we tried 2 other hondata units and they didnt work.
Old Jun 8, 2008 | 05:29 PM
Garage 808 Hatch's Avatar
Default Re: hondata help (1greatEG)
sounds like a bad solder joint in the socket
Old Jun 8, 2008 | 09:21 PM
onefastek9's Avatar
limp mode. what two other units?? two other hondata? then it's him...j/k
Old Jun 9, 2008 | 11:22 AM
1greatEG's Avatar
Default Re: hondata help (onefastek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a bad solder joint in the socket</TD></TR></TABLE> is this an easy fix????????
Old Jun 9, 2008 | 03:52 PM
put the ecu into another car and see if it does this. is it an s300, s200 or s100? if its a 200 or 100, it may be a bad burn, or a chip installed backwards. or as earlier stated, a bad solder on the chip socket or the 4 prong for the hondata
Old Jun 9, 2008 | 04:35 PM
1greatEG's Avatar
Default Re: hondata help (Garage 808 Hatch)
its a s200 and we have not tried that. is there a place i can send it so they can fix it.
Old Jun 10, 2008 | 04:40 PM
onefastek9's Avatar
s200?? time to upgrade.
Old Jun 11, 2008 | 04:41 AM
1greatEG's Avatar
its just all motor s300 would be over kill
Old Jun 11, 2008 | 03:51 PM
try the ecu and hondata in another car, and see if it still does it. try and get another chip burned for you as well, sounds like either a bad burn on the chip or a bad solder joint on either the chip or 4pin
Old Jun 11, 2008 | 04:22 PM
1greatEG's Avatar
im trying to get somebody to check it out if not is there any places from this site i can send it.
Old Jun 13, 2008 | 09:23 AM
Spunkster's Avatar
Are you sure it is a s200 and not a older staged system? What does the serial number on the back say?
broadway
Engine Management and Tuning
Oct 7, 2008 09:09 PM
CaymanNational
Jan 5, 2008 07:33 AM
StolenTeg
Mar 5, 2006 01:07 PM
speedyonez
Oct 20, 2003 06:49 PM
Brian_92GSR
Nov 15, 2001 01:58 PM
