Need help removing broken stud.
Old Jun 7, 2008 | 12:45 PM
DOHC Kid's Avatar
Default Need help removing broken stud.
I broke a stud on my motor mount braket. It's cut flush so I believe I have to use a tap and drill to get it out. I used vice grips on the bottom but it won't budge. Can anyone inform me of how to do this process correctly. I did pick up a little 13 piece Kobalt drill and tap set but came with no instructions.
Thank you.
Old Jun 7, 2008 | 01:06 PM
hatchling37's Avatar
Default Re: Need help removing broken stud. (DOHC Kid)
If you're going to tap it, you have to drill out the old bolt, and then use the tap and put in new threads. You could try an easy out, but if it's already good and frozen, you're probably better trying to just drill it out and tap it.
Old Jun 7, 2008 | 01:34 PM
DOHC Kid's Avatar
Default Re: Need help removing broken stud. (hatchling37)
So in this kit theres two different things. A drill bit and I guess a tap. Do I drill the tap in the broken stud in the middle, and then take the drill bit and drill it in and that will cause it to come up?
Old Jun 7, 2008 | 03:03 PM
1992Si's Avatar
First off what car, engine which mount. ?
You need an easy out to remove the broken bolt after you drill the proper size whole in the broken bolt.
If you broke a stud on the mount by the timing belt that's going to be a bit more difficult.
I would try and buy a replacement from a junkyard.
If it's on the tranny just leave it alone and only use the two bolts.
How much HP is the engine out ?
Old Jun 7, 2008 | 03:30 PM
DOHC Kid's Avatar
Default Re: (1992Si)
It's a GSR motor in a 98 civic coupe. The broken stud is on the Si bracket on the side of the timing belt side. I can't take the bracket out because I can't get the lower timing belt cover off because either the bracket is in the way or the crank pulley...
Old Jun 7, 2008 | 04:05 PM
1992Si's Avatar
Default Re: (DOHC Kid)
Yea I was afraid of that.
You need to drill the broken stud out. Try to dill as centered as possible, start with a small drill and work your way up in sizes.
You may want to use some cutting oil or something like Marvel mystery oil to help the drill cut.
Old Jun 7, 2008 | 06:30 PM
DOHC Kid's Avatar
I'm thinking about picking up a torch tomorrow to try heating it up and hopefully it will loosen up a little bit. I don't want to make matters worse messing it up with the drill bit kit that I've never used before. Think heating it up will help?
Old Jun 8, 2008 | 06:17 AM
1992Si's Avatar
How much of the stud is sticking up ? can you get some vise grips on it the turn it after you heat the bracket.
Be careful with the plastic there.
Old Jun 8, 2008 | 10:57 AM
DOHC Kid's Avatar
The stud isn't sticking up at all. It's dead flat. I can grab the bottom of the stud with vise grips but it doesn't budge at all...
Old Jun 8, 2008 | 05:10 PM
1992Si's Avatar
Good luck with the torch...
Old Jun 8, 2008 | 05:55 PM
mec. pedri's Avatar
i think the torch would be the easiest way to get it out
heat the bracket around the stud and be very careful with the plastic
blueR87
10
Oct 12, 2023 08:04 AM
TEGRA98GSR
Apr 21, 2010 09:47 PM
chickenwing
Sep 15, 2008 09:34 PM
lmike6453
Jun 4, 2008 07:15 PM
george34
13
Feb 22, 2006 11:09 AM
