Starter problem...
Old Jun 5, 2008 | 04:21 AM
djviet2000's Avatar
Default Starter problem...
i have a hard time starting up my car. i took the starter off and checked it at autozone and i passed. it still clicks when i turn the key. this started to happen when i put my system in. i do have a cap and i still have problems starting it up. any ideas?
Old Jun 5, 2008 | 06:36 AM
ModFTW's Avatar
Default Re: Starter problem... (djviet2000)
I had the exact same issue. After a couple of weeks of hunting, i went with my cheapest option first........ I replaced every possible ground to my engine, but instead of grounding say the starter to the car, i grounded it too the battery. Made my self a little ghetto earth grounding kit set up. problem solved no more intermitent starts. haven't had the issue for 4 years now.
Old Jun 5, 2008 | 07:22 AM
wmac's Avatar
^^yeah, check you grounds! especially the one on the transmission.
Old Jun 5, 2008 | 07:32 AM
djviet2000's Avatar
Default Re: (wmac)
check the grounds? why is that? where should i start looking?
Old Jun 5, 2008 | 08:18 AM
wmac's Avatar
because on many components (like your starter) only the 'hot' side is wired. the ground completes the circuit. since your starter is giving you problems, i recommend checking the transmission ground first.
Old Jun 5, 2008 | 12:10 PM
djviet2000's Avatar
Default Re: (wmac)
i did...i took it off and cleaned it...still having the problem. took the battery to autozone they said the battery is good.
Old Jun 5, 2008 | 12:24 PM
wmac's Avatar
dis-connect or pull out the fuse for your system and see if that helps it start.
Old Jun 9, 2008 | 06:05 AM
djviet2000's Avatar
Default Re: (wmac)
disconnected the fuse and still having the same problem...arrgggh any other ideas?
Old Jun 9, 2008 | 06:40 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
im also having this problem sometimes.... need advise
john457
Aug 16, 2005 10:20 PM
5spdIntegra
Mar 26, 2004 12:54 PM
ls_vtec_b18a1
Nov 4, 2002 07:12 PM
brinks
Sep 19, 2002 02:39 AM
digitalhav0c
Aug 6, 2002 01:45 PM
