Starter problem...
Starter problem...
i have a hard time starting up my car. i took the starter off and checked it at autozone and i passed. it still clicks when i turn the key. this started to happen when i put my system in. i do have a cap and i still have problems starting it up. any ideas?
Re: Starter problem... (djviet2000)
I had the exact same issue. After a couple of weeks of hunting, i went with my cheapest option first........ I replaced every possible ground to my engine, but instead of grounding say the starter to the car, i grounded it too the battery. Made my self a little ghetto earth grounding kit set up. problem solved no more intermitent starts. haven't had the issue for 4 years now.
because on many components (like your starter) only the 'hot' side is wired. the ground completes the circuit. since your starter is giving you problems, i recommend checking the transmission ground first.
Re: (wmac)
i did...i took it off and cleaned it...still having the problem. took the battery to autozone they said the battery is good.
