Car having starting problems
Old Mar 7, 2004 | 09:33 PM
5spdIntegra's Avatar
Default Car having starting problems
Well my teg is having some starting problems. Most of the time I turn the key and nothing happens, just a click. If I keep on trying and turn the key fast twice in a row it starts. Some people reccomended me a new battery but that didn't change anything. So now I'm wondering what the problem is? Starter? Alternator? Any suggestions would be appreciated!
Old Mar 7, 2004 | 11:00 PM
xteg95's Avatar
Default Re: Car having starting problems (5spdIntegra)
almost gaurenteeing its the starter.
Old Mar 8, 2004 | 05:12 PM
Default Re: Car having starting problems (xteg01)
Thanks man. It actually started right up today but who knows. There is definitley something wrong.
Can I check to see if it is the starter?
Where exactly is the starter?
Is it easy to replace?
Thanks guys.
Old Mar 8, 2004 | 05:16 PM
stasi's Avatar
Yep, if you're getting a clicking sound, I'd say it's the starter.
Old Mar 8, 2004 | 06:58 PM
Default Re: Car having starting problems (stasi)
I don't know if it's clicking but it makes one single click.
Old Mar 8, 2004 | 07:20 PM
Groove_D's Avatar
starter is located on the tranny's side.
its hard to explain, i have no pics of it.
Old Mar 11, 2004 | 12:00 PM
ubnpast's Avatar
I had the same problem, it would click 3 +/- times and wouldnt start and sometimes did start. It started on some days, others it wouldnt, it got so bad that it wouldnt start at all. I took out the alternator 3 times before i found out what it was. It was the Negative battery cable, it was corroded. Get some jumper cables and ground the negative post on the battery either to another negative post on a battery, or on to the engine mount/block, and start the car. If it works, that is what it is.
Old Mar 26, 2004 | 12:13 PM
Davemell0's Avatar
I'm going to second the grounding problem suggestion, also check the connection between the battery and the starter. I used to have the same problem on my truck when I used to do some off-roading, the possitive connection at the starter had gotten wet and become coroded.
Old Mar 26, 2004 | 12:15 PM
MightyMouseTech's Avatar
Default Re: Car having starting problems (Davemell0)
It is most likely the starter contacts inside your starter. You can get a new set from your dealer, and they are only $10 or so.
Old Mar 26, 2004 | 12:17 PM
len's Avatar
len
From your description, I highly recommend replacing the starter.
To test if it is the starter, you can take a solid object and slightly bang on the outside of the starter. What this will do is break loose some dust inside the starter and you may be able to crank it. But this is not recommended as a replacement. Just a diagnostic. You'll need a replacement starter.
Len
Old Mar 26, 2004 | 12:18 PM
len's Avatar
len
Default Re: Car having starting problems (len)
Other things that I would recommend checking is the electrical contacts for corrosion or loose connection. I would also check the Main Relay under the driver side dash.
Len
Old Mar 26, 2004 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">Other things that I would recommend checking is the electrical contacts for corrosion or loose connection. I would also check the Main Relay under the driver side dash.
Len</TD></TR></TABLE>
Len, you sure you work in a parts dept?
Main relay won't do that.
If it is a Nippondenso starter (which it usually is, you can tell because the solenoid has a square end plate) you can take the end cover off the solenoid and replace the two contacts to the plunger. They are dirt cheap, and this is 95% of the time the ONLY part that goes in these starters. If you have the starter out, it only takes about 10 mins to change them.
Most Honda techs know about this.....
And banging on the starter is not always a good idea. Some starters are made with permanent magnets and will be destroyed if you hit them with a hammer. Just make sure it isn't a perm. magnet type before you hit it, if you are not sure, don't.
Old Mar 26, 2004 | 12:50 PM
len's Avatar
len
Default Re: Car having starting problems (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">
Len, you sure you work in a parts dept? </TD></TR></TABLE>
You can't tell by some of my responses? I gather what I can from the techs, but in no way shape or form am I a trained technician. I usually like to point the person in the right direction. Which in this incident and from another one, you've already established the fact that I'm no trained tech.
Len
Old Mar 26, 2004 | 12:54 PM
Chris's Avatar
also it may be a loose wire on the starter relay. (that is connected to the starter)
john457
Aug 16, 2005 10:20 PM
Fatboy1985
Dec 26, 2003 02:38 AM
crx1856
Aug 20, 2003 10:24 PM
joeg26er
Jun 1, 2003 07:22 PM
Goy091
Jul 7, 2002 06:09 AM
