Car not starting, cranking, priming pump or clicking relays. HELP!
Old Jun 4, 2008 | 11:34 AM
FuNkDrSpOt's Avatar
Default Car not starting, cranking, priming pump or clicking relays. HELP!
I posted before, https://honda-tech.com/zerothread?id=2303519 , and i'm back at troubleshooting this to see if i can help my mom out. I'm just looking for recommendations on what i should do. My electrical skills suck.
<FONT COLOR="blue">*The Specifics*</FONT><ul>[*]Just like the title says, my mom's car isn't starting. [*]It's not cranking, priming the fuel pump or clicking any relays *except* for the starter kill relay.[*]My stepdad was driving it and the ground cable for the battery came loose. There was sparking from the chassis-to-battery ground. [*]I have a hyper-grounding daisy chain system. I think jumped to my transmission and again to my thermostat housing[*]Before it stopped working he told me when he was driving it, the speedo and the tach were going crazy, jumping up and down and that the dash was lighting up and going off. He was able to drive the first 2 days but then the car wouldn't start anymore.[/list]
<FONT COLOR="blue">*What I've done so far*</FONT><ul>[*]I tried to replace the Ignition switch that connects from the fuse box to the steering column.[*]I've replaced the Main relay[*]I've tried to use another battery terminal and ground cable and recharging the battery.[*]I've tried push starting but it's a no-go[*]I've disconnected the ecu just to see if it would crank and that's a no-go too.[/list]
Old Jun 4, 2008 | 11:52 AM
riceburnerryan's Avatar
have you checked the starter and the dizzy? maybe one of them got FUBAR
Old Jun 4, 2008 | 02:25 PM
FuNkDrSpOt's Avatar
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the starter and the dizzy? maybe one of them got FUBAR</TD></TR></TABLE>
I plan on checking the starter next. Where is the dizzy grounded to?
Is there a couple of electrical lines that anyone might recommend for me to check the voltage on?
Old Jun 4, 2008 | 10:15 PM
FuNkDrSpOt's Avatar
Default Re: (FuNkDrSpOt)
bump for an answer. Bump for a hint. Bump for a clue. Bump for a prayer.
Old Jun 5, 2008 | 02:30 PM
FuNkDrSpOt's Avatar
bump
Old Jun 5, 2008 | 09:12 PM
FuNkDrSpOt's Avatar
Default Re: Car not starting, cranking, priming pump or clicking relays. HELP! (FuNkDrSpOt)
ok, so today i go over there and try to get everything working again. I double checked ALL the fuses under the hood. I moved the battery and the main fuse box out of the way to get to the fuel pump relay and fuses ( wiring tuck ).
I unplugged the starter ground and replugged it and all of a sudden it works again. I have no idea what happened but the only thing I could think of is that some fuses/relays were loose.
Hopefully when i put everything back together it stays working.
Hiboost 2.0
Apr 29, 2013 12:09 PM
djw19842005
Jun 22, 2010 05:28 PM
92IntegraPOS
Dec 30, 2008 08:36 AM
FuNkDrSpOt
11
May 21, 2008 01:29 PM
ilovethecrx
Mar 8, 2006 12:15 AM
