how do you pull the timing belt sprocket off the crank ?
Old May 29, 2008 | 07:37 PM
m00nr0ck Si's Avatar
Default how do you pull the timing belt sprocket off the crank ?(h23)
Not the crank pulley but the actual sprocket that the timing belt rides on ....Im trying to replace the front main seal....and ya i already searched for 20 min....
Old May 29, 2008 | 07:52 PM
viper_boy403's Avatar
It just takes a while. You have to just pull out on it and kinda wiggle it back and forth. I'll try to describe it...
So say you are sitting down facing the pulley. Put one hand on each side and pull toward you, alternating strength to each hand. So pull with both hands but kinda rock it back and forth to get it to come out. It took me like 3-5 mins to get it off the first time, after that it comes off a lot easier.
Old May 30, 2008 | 12:29 PM
Default Re: (viper_boy403)
man i Pulled, pryed ,tapped......on it for over an hour and it never budged....thanx for the reply.....
Old May 30, 2008 | 01:51 PM
Apex1972's Avatar
Default Re: (m00nr0ck Si)
Just be very careful. I just had a buddy help me replace mine about 2 weeks ago. it was a little tricky getting that off.I think he used a very small flathead screwdriver to get it started coming off. Be sure to use some Honda Bond on the seal and make sure you do NOT get any rough spots on the crank as they wil eat the new seal up in no time. Actually , I think this may be what has happened to me, because mine has already started to leak a little again. My friend who worked at the Honda dealer here in Macon said we probably did not get the seal in all the way. It may have gotten a little crooked in there. Just take your time and it should be fine. Also make sure you go ahead and replace the cam seals and the balance shaft seal and retainer if you do not have it already. There was a TSB on this issue. part# is 06923-P0A-306
Old May 30, 2008 | 07:21 PM
Default Re: (Apex1972)
So far I have installed ....new timing belts,balance shaft seal and retainer,waterpump,cam seals,valve cover gasket,oil pan gasket,new valve seals,new plugs,ngk wires...all i lack is the front main and i should be good to go....
Old May 31, 2008 | 07:22 AM
Apex1972's Avatar
Well, that should just about cover it then. Just be careful when installing the front main seal. Get a piece of PVC pipe the same size as the seal and use that to drive it in. Also use Honda Bond.
Randysi
12
Oct 20, 2011 03:00 AM
Annihilator
Jul 23, 2008 01:32 PM
Powered by VTEC
Jan 29, 2008 05:58 PM
99blackdc2
Jul 28, 2006 07:23 PM
sbigblack02
Apr 3, 2004 07:21 AM
